eem2am
Banned
led lamp circuit
Hello,
Please could you examine the enclosed circuit which is a parallel LED driver with LED failure detection.
If any LED fails open then the lamp must be turned off by taking the LED driver’s (LT3517) shutdown pin low. (i.e.”one LED off, all LEDs off”)
***Whole schematic of lamp and LED failure circuitry ...........
http://i27.tinypic.com/35jlef7.jpg
***Close ups of Lamp with LED failure circuitry.....
***BJT’S
http://i30.tinypic.com/206ewi0.jpg
***LEDs
http://i25.tinypic.com/9kbddh.jpg
***LT3517 LED driver
http://i25.tinypic.com/2qw2c2h.jpg
The LED current in each LED is 166mA .
Input volts (“BATTERY”) is 13.5V
When any LED fails open………
..Q2 goes OFF
..which allows C5 to charge up
..which switches ON Q3
..Which takes the LT3517’s SHDN pin low
..which turns OFF the LED lamp
Unfortunately, every about 1 in 10 PCB’s with this circuit do not stay ON when switched ON. (even with all LEDs “healthy”)
-instead the LEDs flash for about 400ms and then the LEDs just go OFF and stay OFF.
-Then, when switched ON at another time, it maybe works OK.
So , what is happening is that this circuit is giving intermittent faults
-that is , it is sometimes switching itself OFF when the LEDs have NOT actually failed.
Please – do you agree with this here conclusion about why these intermittent faults are occurring with this circuit………….
..in other words, this may be why the lamp is being turned off even when NO LEDs have failed…………….
Q2 (NPN) parts have variable hfe’s –indeed the hfe will vary with temperature also.
-So sometimes, a particular Q2 on a particular PCB will not be switched on by the current through R9 (220K) and so will not manage to stop C5 from charging up and turning Q3 ON , -which turns off the PWM controller..
Do you agree with this analysis?
here is the .asc file for the free LTSpice simulator...
also
Hello,
***BJT’S
***LEDs
..Q2 goes OFF
also
