sfields
Newbie level 1
Here is another led issue... I need to connect one 5000mcd led to 110 volt as an inticator light. I need to do this in several locations, so I don't want to buy transformers to produce DC (I'm using lcd's for durability... transformers like to burn up). I have planned to use a 7.2k resistors (2w), followed up by a small diode to deal with the AC. Does this make sense? I'm assuming it would go: pos 110 voltage connected to resistor, then connected to the diode, then run to the positive side of the led. The neg side of the led would go back to the common side of the outlet. If this will work, does the diode have a direction it should go? how about the resistor? Is it correct to hook both of these up on the positive side?
Thank you so much,
Scott Fields
Thank you so much,
Scott Fields
