svarc
Newbie level 2
hello there. i am using 10 red 5mm led's in parallel at 20mA on 5V with single 15ohm 2W resistor but the resistor is heating up like crazy (pls dont ask me why i am using only one resistor for all led's). i measured the voltage drop on this type of led its exactly 2V. is there anything else that i should know that's making my resistor to heat up?
Maybe my power calculation is wrong. Total led current consumption 10x0.02A=0.2A so P=0.2A x 5V=1W so i am using a resistor with double the calculated wattage.
Thanks in advance and best wishes.
