daiashthomas
Newbie level 3
My name is Ashley, I live in the UK, I work with alarm systems but have not worked at a component level for quite sometime.
I have a variety of bit at my disposal and have retro fitted my gun cabinet with a 12vdc led strip light.
The Magnetic contacts I use in work are what we call normally closed for example when a door is in its closed position and magnet is within range, the reed switch is closed.
Basically this would normally mean that the light would be on when the door is closed ha ha.
So I'm using the reed to switch the negative to control a relay to inturn switch the positive to feed the LED strip.
I have reversed this also so the positive is switching the relay through the magnetic reed, but on both circuits the 12v power supply is buzzing when the door is closed.
I have tried a different supply in both circuits too, but it still buzzes.
Could it be that I need some type of diode or current limiting resistors in the circuit somewhere?
I was only trying to use a magnetic contact, as Trying to position an actual mechanical push to break switch inside the cabinet is going to be an absolute nightmare to position and secure in place.
Thanks in advance!
Thanks in advance!
