Batur
I am trying to drive single 30W chinese leds using the below circuit but using 12V vcc:
Vf of the leds are 12V and I want to keep Led curent about 2.3A. However while I can drive the white led without a problem, blue and UV leds whose specs (Vf,Iled) are identical do not drive more than 1.5A and 0.2A respectively.
When I connect the leds directly to 12V both draw nearly 3A, TPS16500 is a boost driver so i thought maybe input voltage was not enough so increased it to 15V but there is no change in the current. My supply can provide nearly 10A so I dont think its limiting the current (also white led has no problems).
I think my circuit is somehow limiting the current but I cant find the cause. The driver is not running very hot, current sense resistor is adjusted for 4A. Any help would be greatly appreciated.
Best Regards
Best Regards
