nguyennam said:Why you use PIC when there is ICL7107 or other similar dedicated ICs still active at Intersil and other manufacturers?
Why you try to bump into complicated matter when not necessary?
Fragrance said:in some casses ypu right when you just need a simple voltmeter chip with out auto decimal point shift but when you are making some thing special then controller provide a good solution
regards
Fragrance
