LED dimmers for 5w/12watt white lamps
vimalkhanna
Full Member level 6
Full Member level 6
delhi
Need to have 10% to 95% dimming facility for my 5watt LED white light LED .
Pulse control ,,phase control ,pulse suppression control circuits are needed with RFI filtering .
Suggestions ??
Designed Pulse position modulation rather than PWM .
The frequency was lowered and the Vmax. was also trim controlled thru a TL431.
The solution was reached .
Detailed readings of load currents were monitored and extra design steps were taken to improve cutin voltage switching .
However the LEDs start with a jerk.
PPM does not change the space/mark ratio and it's used in different applications ..
Start with 555 in its classic 2-diode PWM configuration .. see attached picture ..
Then you can add an RF-choke and some caps to reduce interference, if required ..
IanP
:wink:
there are no attachments in file ..like to see your detailed schematics pic..
