led dimmer with ka3844
nhghost
Newbie level 3
Newbie level 3
led dimmer with uc3844
led dimmer from 220V, 50hz.
I can do with 555 but can't with ka3844 (or uc3844 or uc3842)
I don't know how to control duty cycle (Ratio) with ka3844...help..........
Try varying the current on pin 3 as shown in the test circuit.
omg. thank you very much.
before your reply, I tried test circuit. but it not work :((
after your reply, I try again. remove pin 1 and pin 2 --> work :D
Now I can control duty cycle :idea:
thank you very much!!!!!!!!!!!!!!!!!!!!!!
---------- Post added at 11:31 ---------- Previous post was at 11:21 ----------
not enough post, can't add image. Now enough :D
Why I use uc3842, it work but when use uc3844, haven't signal output
the circuit I remove pin1, pin 2
when V pin3>xxx --> output=0
ps: I speak English very bad :cry:. thank for read my thread :-?
