Salvador12
Full Member level 4
Hey folks.
I need a circuit that is very similar to a LED chaser, essentially a line of mosfets that get switched on/off in series such that the position of the "ON" mosfet changes in time from one side to the other.
Now unlike a LED chaser, I need several mosfets to be ON simultaneously instead of a single one.
Imagine a row of 30 mosfets and ideally I would need for most of them to be ON at any single moment while a few get switched OFF along the way so that the "OFF" position moves in space and time.
This is a test so I don't need high voltage or current switches. And I would need the "OFF" position to move along in a changeable speed and ideally very fast too.
I am not sure how that translates into switching frequency but the linear speed of the "OFF" position should be up to some 1000 km/h and more if possible.
Shouldn't be too fast for semicondcutors.
So guys , can anyone here help me out with ideas or IC's and part numbers , I'm sure there must be a circuit similar to what i need already out there.
