kender
led temperature sensor
Folks,
Have anyone used the forward voltage of the LED to estimate LED's own temperature?
Here's my application. The light from the LED is used periodically for spectral measurement*. The spectrum of the LED itself changes with temperature**. I would like to monitor the temperature after LED is turned on and make measurements when it stabilizes. The LED has a constant current driver, so the current into the LED is known.
I'm sure somebody thought about this. Do you think it can work?
- Nick
* Somewhat crude measurement, compared to other light sources.
** An article on relationship between LED spectrum and temperature https://www.jstage.jst.go.jp/article/jlve/32/3/32_288/_article
Folks,
- Nick
