LED and heat sinks using two layer fr-4
frank_eda
Newbie level 5
Newbie level 5
Hello,
I am new to PCB design.
I understand the when using an LED we can use a 2 layer Fr-4 with thermal vias. The question is if I want to add an additional heat sink to the bottom of the PCB will that mean I will have to show the copper? If so, how will this prevent solder wicking when filling up the thermal vias?
thanks
frank
Usually it makes only a small difference, because the heat_transfer_area is much bigger than the LED one.
Klaus
Klaus
Hello Klaus,
I am not sure i follow? Please elaborate. Thanks!
I understood the question wether you should use solder stop or not.
I say it makes about no diffdrence in heat transfer, so use solder stop.
Klaus
I would appreciate a clear question respectively a drawing first. Too many unsaid presumptions.
Oops. I replied to the wrong person and quote.
@Klaus - Got it! Thanks!
