Least Mean square algorithm?
asic1984
Full Member level 5
Full Member level 5
least mean square algorithm*pdf
hi
in LMS algorithm ,i suppose to change the weights by this equation
w(n+1)=w(n)+ηe(n)*x(n)
where w: weight ,e:error ,x:input
do i have to change π in every iteration,how to calculate it if i have to vary it,what value shold it be if it is constant
thanks too mcuh for your help
asic1984
I think you might be a littel confused here.
It looks like n is used in your equation to represent the sample (or iteration) number.
So n is a positive integer number, starting at 0, and incrementing.
Therefore
n=0,1,2,3,4,5.......etc
I hope that answers your question.
Maui
hi
i know that n is the iteration i mean the η ,it was mistake in writting
the small constant η is called the step size, or learning rate.
It is chosen.
It is a constant so when you choose it, it stays the same.
It has to be chosen to fit some constraints, not sure but I don't think this is hard.
see
cwww.ee.nctu.edu.tw/course/asp/ASP04.pdf
or lots of other places on the web.
Maui
