learning embedded systems
Embedded System is a huge field by itself. The basics of embedded systems starts from simple microcontroller programming to SOC development. However one can get started with microcontroller and arm programming and also the basics of RTOS. However you can have a look at the video lectures available in youtube. This might be good to start with.
Yes...Embedded Is wast domain...First you should have thorough knowledge in C/C++ Programming so better to start with programming, after that learn on LINUX Programming, Micro Controllers, RTOS, TCP/IP Protocols, And some protocols like I2C, CAN, RS232, Bluetooth etc....
I totally agree with you yanamaddinaveen. Programming in C/C++ with help of some cross compilers like Keil for different microcontrollers is best way to start with.
basic idea about electronics ,
then some programming language (C/C++).
Again select a controller basically 8051 is easy to begin .
