Learning CCP register of PIC12F683
MPLAB doesn't have a limit. Neither does mikroC PRO licensed (only free demo version does).
The max limit is what can be stored in the PIC.
You can build large programs using both. However mikroC will require the licensed version.
You can see the pricing here: https://www.mikroe.com/mikroc/pic/
As of now it is $249.00 USD without discount and $199.00 USD with discount.
You should choose to buy the license only if you have used mikroC, are happy with it and are sure that the money spent for the license would be money well-spent.
Please let me know that i have installed MPLAB 8.88v ,it is different from MikroC but i want to learn programming of MPLAB
where I find and please give any link.
The tutorials I previously posted in reply #9 are particularly good at demonstrating the use of MPLAB in conjunction with the Hitech C Compiler for PIC10/12/16.
I have also attached the example code for the previous tutorial lessons.
The documentation and user manuals for the MPLAB IDE and Hitech C Compiler for PIC10/12/16 are available from the links provided below:
HI-TECH C Compiler for PIC10/12/16 MCUs v9.83 User Guide
Hi-Tech C PRO Compiler for the PIC10/12/16 MCU Families Part 1
Hi-Tech C PRO Compiler for the PIC10/12/16 MCU Families Part 2
Using the Timer1 Gate Feature to Measure the Width of a Pulse Webinar - Uses the newer MPLABX and XC series compilers
AN1251 - Using HI-TECH C(R) and a Timer to Interface Mid-Range PIC(R) MCUs with UNI/O(R) Serial EEPROMs
Source Code for Above Appnote
I would recommend working through the tutorial PDFs I've uploaded in order, this should give you an excellent foundation for further study of MPLAB and Hitech C Compiler.
If you are using the newer MPLABX and the XC series compilers download and study the latest tutorials from the site below:
BigDog
  • MidRange C Example Code.zip
