T
treez
We wish to use a lead acid battery for our emergency light product.
We know that there is only one way to charge lead acid, and thats this.
Trickle charge at <C/10 until voltage > 2.1V/cell
Constant current charge till cell voltage = 2.35V/cell
Topping charge which maintains the voltage at 2.35V/cell (the current slowly reduces)
-when the topping charge current has reduced to 0.03C, then go to ...
Float charge which just regulates the cell voltage to 2.25V/cell
..The above must be adhered to if you want any decent lifetime out of the lead acid battery?
My questions are.....
1)...Can the constant current phase be done at any current level?...what ranges of current are allowable?
2)...How much does the 2.35V/cell figure change with temperature?
3)....How much does the 2.25V/cell change with temperature?
4)....Supposing i have a constant current source of C/10 (which can be PWM'd on and off at any duty)...then is it impossible to charge a lead acid battery?
