jinxx
Newbie level 3
LDR based switch
I'm trying to make a transistor-based switch that will turn on when the resistance from the LDR is larger than a certain resistance and will turn off when the resistance is less. I've made switches using 2n3904's that turn on when the resistance is low, I just need that for the other way around.
Also, it has to be as efficient as possible as it will be used in a solar application.
Thank-you in advance for your help
-Jinxx
-Jinxx
