dksoba
Member level 2
LDO vs Non-LDO
I think I understand what the difference is for LDO vs non-LDO voltage regulators, which is than an LDO voltage regulator needs a smaller in vs out voltage difference. AKA a 5V LDO can regulate to 5V at 5.5V where a non-LDO would need 7V to regulate to 5V.
My question is, if you have a 24V power supply, and you need a 5V regulated supply, using a non-LDO will generate a lot of heat. If you use an LDO, will the power consumption be less?
Matt
Matt
