dtz_lou
Newbie level 6
Hi all
I face a strange issue when simulating the LDO together with a LC VCO. I want to calculate the PSRR at the output of LDO connected together with the VCO. I run AC simlation
and I take quite strange simulations results( maybe dangerous) at the LDO voltage output. I attach you a screenshot for getting a better feeling about the possible problem.
The architecture of VCO is a LC nmos cross-coupled with a PMOS current source throw the bias current in the inductor. there is a big decoupling capacitor connected between the LDO
voltage output and ground (around 100pF) As a result an RLC resonator circuit is accomplished. and the peak arises at frequency F=1/(2*pi*sqrt(LC))\[\approx\]24MH.
Do you have any comment on this? Is it dangerous? And if yes how can I verify it?
