deep_sea
I wonder what is the motivation behind taken a ratio of LDO output voltage through a resistive divider and feeding it with a reference? what are the disadvantages of comparing Vout to VREF directly? Is the availability of a particular reference voltage the main reason?
If the LDO output level is more convenient as a common mode voltage for the input of the error amplifier and the reference voltage is not available and will be part of the LDO design, would it be better to design a reference voltage similar to the LDO required output?
