Purushotham S
Newbie
Hello, I am designing an LDO. I am using two stage opam as error amplifier. I am connecting the output of opam to the gate of pass transistor. How to calculate load cap and Slew rate for opam calculation,l
Hello Here are my specsIf you designed it then you ought to know how to compute the gain , BW and Rout of the design with various conditions with negative feedback. Then you can determine load range and load sensitivity on stability. A Bode Plot is used to measure phase margin and plot how load R and X(f) affects phase margin. A partial derivative may yield the sensitivity of each part in your gain equation. When using a FET bypass transistor, there may be unstable zones with too small and too large a load capacitance . An internal load Cap and internal RC compensation in a small FET LDO serves to extend gain and phase margin while reducing step load peak errors.
Critical specs;
Vin range
Iout range
PSRR @ 10 MHz = GBW/10 MHz
Compensation RC pole
Minimum load C
also:
Step load error
Thermal error
Input regulation error
Output noise figure.
shall i increase the gain to 10000? and how to decide a two stage opam for that mosfet, Any resources?You should do some research and find the excellent publication on this cascode FET design.
OA's are too slow.
Ignore my OA comment and read the rest again, then take action. It took me 1 minute. Prefer to note Researchgate.comshall i increase the gain to 10000? and how to decide a two stage opam for that mosfet, Any resources?
I think I am beginner in this field, can u please let me know any good resources for it. I would be so helpfulIgnore my OA comment and read the rest again, then take action. It took me 1 minute. Prefer to note Researchgate.com
There are so many papers online. This is what I wanted you to learn how easy it is to find them. But it seems you did not try. Why is that?I think I am beginner in this field, can u please let me know any good resources for it. I would be so helpful
