LDO after another LDO: is this fine?
gilbertomaldito
Full Member level 3
Full Member level 3
To Linear Regulator Experts,
Is it fine to attached another LDO after the 1st LDO?
For example, I need 5.5V and 1.8V for my internal circuits and the input voltage is 10V.
1st LDO vin=10V, vout 5.5v
2nd LDO vin=5.5v(from 1st LDO), vout=1.8V
Is this fine?
-Andrew
Should be fine. What currents do you need for each rail ?
This is a standard trick in analog circuits which need very low noise from power supply ripple.
How will I know the required current output? For my case, the output of the Regulators will just be fed to VDD(or V power of my circuits example)
Power Supply Ripple - is this the input of regulators you are talking about?
