LCF Meter using PIC16f628
lcf-metr
I have build this LCF meter, but i noticed unexpected spurious oscillations in capacitor mode. On site with modifications i have noticed that 68pF capacitor has to be added in order to eliminate these oscilations, but i have not found information where to connect this capacitor. Can anyone tell me where to put this capacitor?
the schematic of the pic lcf meter
Sorry for my reply to this very old topic but i can't find schematic for this meter (links to epemag doesn't work now)...
The only working is the one to modification's page.
Can you tell me where i can find schematic and/or more infos???
Excuse me again and a big thank you in advance.
Bye.
lcf meter with 16f628
same here z
if someone have this pdf version ot the magazine pls upload here or email me @ ist3k@yahoo.com
Thanks
p.s i try emule
i think i fount it
Reactions: kampon
    kampon
pic 16f628
HERE'S WHAT YOUR LOOKING FOR
s metr in pic16f628
wheres the source code for the pic16F628, buddy?
this circuit will and shall not work without it,
can anyone upload the code
many thanks
l.c.f meter
Here is the code and some coments from John becker
PICstudent
lcf meter homemade
PICstudent
thanks buddy!
but was the code you've shared were from elektronika.ru,
code of EPE differs from the others i think
still its a great helped, just edit the source code though
thanks again
16f628 f-meter
hi
I have no idea where the code is from.
The only thing I am sure is that I uploaded it from my collection in my HDD,under the folder 'LCF meter'
picstudent[/quote]
pic16f870 lc meter
I'm looking for that source code to, but I can't find it anywhere.
Please can you help me....
Fred
l c f meter pic
Fred
The sourse code is in the above post
If you lack points, I already have donated 20 points for you
picstudent
lc meter pic16f628 hex
Thanks.....
Yes found it, but can you please tell me which compiler I must use for it?
When using MPLAB 7.31 I will get an error: Expected (END)
Fred
lc meter pic16f628a schematic
Hi
Sorry. I am not sure.The pdf version of the article might have some references to it.
What I did was convert it for MPASM. (My project is not yet completed. Little other works, So diverted from it.)
Start again after some time.
picstudent
lfc meter
my question is why did the guys at EPE use an external crystal. and why the 3.2768MHz crystal
Answers: Crystals are much more accurate than internal oscillators. 3.2768 divides evenly by binary bit numbers (16,32,128...).
gsm forum
Does it work on 16F628A? Did anyone tried it? It dont seems to work on mine..tried a few thing
pic lcf
HI,i tried too with MPASMWIN5.03,but i got error message:129EXPECTED, END
If someone has the right ASM & HEX file, could you please put in on the board? Thanks a lot!
pic lcf meter *
The original source is written for TASM Compiler then you have to Change the source code to compile via MPASM
Added after 1 minutes:
It's working till now using 16F628A I think you have a problem feel free to ask.
Added after 2 minutes:
As I said before you have to change the source code to work under MPASM
You have to change these :
% to B'
$ to H
.ORG to ORG
.EQU to EQU
lc meter*pic16f628
this is good projects for Amateur purpose
I modify the source code for PIC 16F630 , 16F873
and work very good.
for more info call me;
Nader Eivazzadeh
+98 914 310 1564
meters with pic16f628
Hi
Today i have made this project but i seen garbge on lcd after prog the pic may be code is not correct some one have a working version of the code can he please share it. further is 16f628 code can work on 16f628a
regards
Fragrance
lcr 16f628
You have a look here **broken link removed** ; Construction LCFMetr
