LCF Meter using PIC16f628
SphinX
Advanced Member level 3
EGYPT
lcf meter
There is LCF meter project using PIC will published in EPE Mag. FEB/2004
The Meter measures
L 1uH - 10H
C 1pF - 6500uF
F 0.05Hz - 5MHz
The oscillator based on CMOS NAND or inverters gates
I will build it
SphinX
lc meter pic16f628
please share information or EPE Mag. FEB/2004
I not have EPE Mag.
thank you
pic lcf meter
This issue will published in 2 weeks.
The jan/2004 issue is online now
epe lcf meter
Where can I download the jan/2004 issue.
lcf-meter
lc meter 16f88
You can download it from here with compliments. 1/5
/ Warning #1 - Files deleted. Direct link is already posted in above link, so don't waste elektroda bandwidth by uploading useless files!
john becker lcf meter
Hi 212853,
There is a rule in elektroda.
Don't upload any files , you can download it from the internet
Bye
pic lcf meter by john becker
Hello all,
EPE Mag. February 2004 is now UP.
use the following link.
lc meter pic 16f628
Where to get a 3.2768 Crystal.
pic lc meter
Can you say to me if this project works correctly?
lcf meters
circuit does work, with some comments. First, it depends on the manufacturer of the 4011 that you use. Some work without modification, others require a little tweaking. I built 3 of these and had to add a 43 pf cap across the second gate of the 4011 to get the meters to read linearly. There was a complete page of discussions on this in, I believe, the May issue of EPE in the readers letter section.
Hope that helps you...Mike
lcf meter pic
It is free resonant lcr project,where to find lcr with variable frequency and testing voltage.
lcf epe meter
hi
some one have the orignal asm file for 16f628 as the file on there web page have some bug in it
lcf meter pcb
Hi all
the PDF file of Epemag Feb2004 is protected and I want to extract the pages of this article
know you the password of this number?
l-meter pic16f628
Go to EDA E-Books Upload/Download in the EDA Forum Index.
I have already this file but I want unlock this document for to extract two pages.
I have to use" Advanced PDF Password Recovery Pro" unsuccessfully.
recommendation for lcf meter
Hi, all
About LCF METER using 16F628 check at
and
fui...
lcf meter schematic
I finished my LCF meter from EPE, but i have problems with it. It measures ower 1uF exactly the double capacity, so 2*cap. value. Below 1uF, it works perfectly. I used the firmware, from EPE. What can be the problem? The another thing is, that when I turn on the unit, it displays "capacitor time out" message. When i take a wire, and make a shortcut between the measuring points, and aftet a sec. I remove it, it works.
Any idea????
