Lcd_Custom_Out time problem
nadre25
Member level 3
Member level 3
Hi, we've encountered a problem with regards to the
"Lcd_Custom_Out" function of the PIC16F877A
our output waveform without the Lcd_Custom_Out looks like the figure below
when we added Lcd_Custom_Out the waveform became
there's a delay because of the Lcd_Custom_out.
Is there a way to reduce the delay of the lcd_custom_out? or is there a certain code that would separate our lcd functions with the other functions.
I do not believe so, MikroC does not release the source code for any of their libs. Therefore, you cannot analyze or modify their code in any way.
If you are having difficulties with their library routines, you may want to write your own LCD library or port a third party's LCD library with source code to the MikroC compiler. The end result being, you now have control and can make adjustments to fit your needs.
There are quite a few LCD libraries openly available with source on the NET.
