LCD to PIC16f877 in assembly
budimanc
Newbie level 5
Newbie level 5
Indonesia
Hi, i had some problem with my program, when i compile its seems ok.
But when i tried simulate it in hardware simulation using proteus, the text doesnt appear. I'm using Port B as data dan Port A to control. Can you please check it.
The program is
 LIST P=16f877, c=100, n=55, st= OFF     ; pilih tipe prosesor
 include "p16f877.inc"  ; sertakan file penetapan nama-nama register
Enbl 	equ 	0
RSel 	equ 	1
RW	 	equ 	2
RBPU 	equ 	7
lcdram1	equ	0x80 	; alamat DDRAM baris 1
temp 	equ 10h
	cblock 0x20
		tundacch,tundac5,karcch,index
		disp1:16 		; buffer tampilan brs 1
		bufptr 		; pointer alamat buffer tampilan
		lcdram 		; variabel untuk alamat DDRAM
	endc
	org 	0x00	; awal program reset
	nop
   	goto 	start
;Rutin menginisialisasi PortA dan PortB.
InitPort:
 	bcf 	STATUS,RP1 	;
 	bcf 	STATUS,RP0 	;select bank0
 	clrf 	PORTA 	;buat semua Port_A rendah
 	bsf 	STATUS,RP0 	;select bank1
 	movlw 	B'00000110' 	;setel Port_A sebagai digital I/O
 	movwf 	ADCON1 	;saat power-on reset port_A ana inputs
	clrf 	TRISA 	;buat semua Port_A output
	movlw 	B'00000000' 	;PORTB all outputs
 	movwf 	TRISB 	;
    	return
;menerbitkan tundaan 1 mdet (1000 siklus) termasuk call
tunda1ms: 	movlw	d'199'	;
 	movwf	tundacch	;
tnd11:	nop
	nop
	decfsz	tundacch,f	;
	goto 	tnd11	; lup 199*5
 	return
;menerbitkan tundaan 5 mdet menggunakan tunda1ms
tunda5ms:
 	movlw	d'5'	;
 	movwf	tundac5	;
tnd15:	call	tunda1ms
	decfsz	tundac5,f	;
	goto 	tnd15	;
 	return		;
;menerbitkan pulsa Enable LCD
aktif_E:			;
	bsf  	PORTA,Enbl  	;bawa E ke logika 1
	nop  	  	;tunggu sesaat
	bcf  	PORTA,Enbl  	; kembalikan E ke 0
    	call 	tunda1ms   	; tunggu selama 1 mdet
    	return
; menginisialisasi LCD
initlcd:
; modus komando
 	bcf 	PORTA,Enbl 	;bawa Enable ke rendah
 	bcf 	PORTA,RSel 	;pilih reg Instr, RS=0
 	bcf 	PORTA,RW 	;pilih modus tulis RW=0
	call 	tunda1ms	;beri waktu bagi kontroler LCD utk init
;Function Set
	movlw 	0x38
	movwf  	PORTB
	call 	aktif_E  	; aktifkan Enable, beri waktu bagi kontroler
;Display OFF
	movlw 	0x08	; kode mematikan tampilan, kursor dan kedip
	movwf  	PORTB
;Display and Cursor ON
	movlw 	0x0E	; kode hidupkan tampilan & kursor tanpa kedip
	movwf  	PORTB  	; 0000 1110
	call 	aktif_E  	; aktifkan Enable dan beri waktu bagi kontroler
;Entry Mode Set
	movlw 	0x06	; kode tampilan diam - kursor bergerak kanan
	movwf  	PORTB  	; 0000 0110
;Cursor/Display Shift
	movlw 	0x14	; kode tampilan diam - kursor bergerak kanan
	movwf  	PORTB  	; 0001 0100
	call 	aktif_E  	; aktifkan Enable dan beri waktu kontroler
;Clear Display
	movlw 	0x01	; kode untuk membersihkan tampilan
	movwf  	PORTB  	; 0001 0001
	Return
;mengisi buffer tampilan dengan blank
kosongbuf
	movlw 	D'16' 	; Set up counter
	movwf 	karcch
	movf 	bufptr,w 	; First PIC RAM address
	movwf 	FSR 	; Indexed addressing
	movlw 	0x20 	; kar spasi ASCII
simpan:
	movwf 	INDF 	; Store blank character in PIC RAM
	decfsz 	karcch,f 	; Done?
	goto 	almtbrkt	; no
	return 		; yes
almtbrkt:	incf 	FSR,f 	; Bump FSR to next buffer space
	goto 	simpan
; Rutin pengiriman teks dari buffer ke LCD
tampilcd:
	bcf 	PORTA,Enbl 	; E line low
	bsf 	PORTA,RSel 	; RS line low for control
	call 	tunda1ms 	; Delay
	movlw 	D'16' 	; pencacah karakter
	movwf 	karcch
; Get display address from local variable pic_ad
	movf 	bufptr,w 	; alamat awal buffer teks
	movwf 	FSR 			;
getkar:
	movf 	INDF,w 	; ambil karakter dari buffer
	movwf 	PORTB
	call 	aktif_E 	;kirimkan ke LCD
	decfsz 	karcch,f 	; turunkan pencacah
	goto 	karbrkt 	; sampai habis
	return
karbrkt:	incf 	FSR,f                   ; Bump pointer
	goto 	getkar
; Memilih alamat DDRAM untuk baris tampilan LCD
; alamat buffer ada di variabel lcdram
baristpl:
	bcf 	PORTA,Enbl 	; aktifkan E (E= 0)
	bcf 	PORTA,RSel 	; pilih IR (RS= 0)
	call 	tunda1ms 	; tunggu 1 ms
; pilih alamat pertama baris
	movf	lcdram,w	; alamat dan bit komando
	movwf 	PORTB
	call 	aktif_E 	; Pulse and delay
; pilih reg data DR
	bsf 	PORTA,RSel 	; pilih reg data (RS= 1)
	return
; Subrutin membawa teks pesan dari mem program ke buffer RAM
; input: bufptr= alamat buffer
; 		 w= offset di buffer
; local: psn1= rutin pencatu pesan dengan 0 sbg terminator
; 		index= variabel indeks tabel
bawapsn1:
	movwf 	index 	; atur indeks buffer
	movf 	bufptr,w 	;
	addwf 	index,w 	;
	movwf 	FSR 	; muat ke FSR
; mulai pembacaan tekes dari indeks ke 0
	movlw 	0 			;
	movwf 	index 	; awali index dengan 0
ambilkar:		; w digunakan sepagai penunjuk
	call psn1 		; ambil karakter dari tabel
	andlw 	0x0ff	; Test apakah 0 (terminator)
	btfsc 	STATUS,Z 	; Test zero flag
	goto 	endpsn1 	; End of string
; simpan karakter di w ke buffer
	movwf 	INDF 	; buffer ditunjuk FSR
	incf 	FSR,f 	; arahkan ke buffer berikut
	movf 	index,w 	; naikkan indeks dan muat ke w
	addlw 	1 	; untuk karakter berikutnya
	movwf 	index 	;
	goto 	ambilkar 	; ulangi
endpsn1: 	return
; Rutin membawa teks pesan brs-1 dari mem program ke buffer di file reg
psn1:	addwf 	PCL,f 	; ambil elemen ke-w
	retlw 	' '
	retlw 	' '
	retlw 	' '
	retlw 	' '
	retlw 	'E'
	retlw 	'm'
	retlw 	'b'
	retlw 	'e'
	retlw 	'd'
	retlw 	'd'
	retlw 	'e'
	retlw 	'd'
	retlw 	' '
	retlw 	' '
	retlw 	' '
	retlw 	' '
	retlw 	 0
start:
   	call 	InitPort 	;initialize port B
	call 	tunda1ms
	call 	initlcd
	call 	tunda5ms	;beri waktu untuk lcd untuk initialisasi
; Simpan alamat awal buffer teks tampilan PIC
	movlw 	disp1 	; alamat awal buffer teks tampilan PIC
	movwf 	bufptr 	; muat ke variabel penunjuk
;awali buffer tampilan blank
	call 	kosongbuf  	;kosongkan buffer tampilan PIC
; Bawa teks ASCII ke buffer tampilan di PIC
	movlw 	d'1' 	; Offset tampilan
	call 	bawapsn1	; pindahkan teks ke buffer
; Setel alamat DDRAM untuk baris-1
	movlw	lcdram1	; tunjuk alamat DDRAM baris-1
	movwf	lcdram
	call 	baristpl	;setel alamat DDRAM
	call 	tampilcd	;tampilkan teks
loop: goto 	loop
End
[/code]
It might be easier to check your proteus .dsn first as the fault may be in that - can you post it together with the .hex file.
    budimanc
eh i just got the solution, i just having a small mistakes in my proteus.
Now i'm trying to generate text in lcd using cgram, but i dont know how.
can you please modify this above program using cgram just to show A word using CGRAM not DDRAM
