kiranmayik
lcd_send_command( hd44780
hi everyone,
i tried interfacing at89c51 with 20X2 lcd display(ODM-20216S).
i have connected port1 to LCD and P3.0 to RS, P3.1 to R/W, P3.2 to E.
but the LCD is not showing any output.
this is the code:
;communicating with lcd
;checking busy flag before sending data, command to lcd
; P1= data pin, P3.0=RS, P3.1=R/W, P3.2=E pins
ORG 0H
MOV A,#38H ;initialize lcd 2 lines
ACALL COMMAND ;issue command
MOV A,#0EH ;lcd on, cursor on
ACALL COMMAND
MOV A,#02H ;return home
ACALL COMMAND
MOV A,#01H ;clear lcd command
ACALL COMMAND
MOV A,#06H ;shift cursor right
ACALL COMMAND
MOV A,#80H ;cursor:line 1,position 0
ACALL COMMAND
MOV A,#'L' ;display letter L
ACALL DATADISP
MOV A,#'C'
ACALL DATADISP
MOV A,#'D'
ACALL DATADISP
HERE:
SJMP HERE ;stay here
COMMAND:
ACALL READY ;check if lcd ready
MOV P1,A ;issue command code
CLR P3.0 ;RS=0 for command
CLR P3.1 ;R/W=0 to write to lcd
SETB P3.2 ;E=1 for H-to-L pulse
ACALL DELAY
CLR P3.2 ;E=0, latch in
RET
DATADISP:
MOV P1,A ;issue data
SETB P3.0 ;RS=1 for data
CLR P3.1 ; R/W=0 to write to lcd
ACALL DELAY ;give lcd some time
RET
READY:
SETB P1.7 ;make P1.7 input port
CLR P3.0 ;RS=0 access commang register
SETB P3.1 ;R/W=1 read command register
;read command register and check busy flag
BACK:
CLR P3.2 ;E=0 for L-to-H pulse
SETB P3.2 ;E=1 L-to-H pulse
JB P1.7,BACK ;stay until busy flag=0
RET
DELAY:
MOV R3,#50
HERE1: MOV R4,#255
HERE2: DJNZ R4,HERE2
DJNZ R3,HERE1
RET
END
i'm not sure how much delays to give.do i have to give delay at the starting for power on.if so how much?and approximately how much delay is required for the enable pin.
please help.
thank you.
hi everyone,
this is the code:
ORG 0H
ACALL COMMAND
ACALL COMMAND
ACALL COMMAND
ACALL COMMAND
ACALL COMMAND
ACALL DATADISP
MOV A,#'C'
ACALL DATADISP
MOV A,#'D'
ACALL DATADISP
HERE:
COMMAND:
ACALL DELAY
RET
DATADISP:
RET
READY:
BACK:
RET
DELAY:
MOV R3,#50
HERE1: MOV R4,#255
DJNZ R3,HERE1
RET
END
please help.
thank you.
