LCD PHILIPS LC171W03-C4
kevinro40
Newbie level 1
Newbie level 1
lc171w03
Salut!
Am si eu un asemenea TV, care dupa ce nu l-am folosit catva timp are o manifestare ciudata. Dupa maximum jumatate de ora de la pornire, apar pe display , in partea din stanga, cateva dungi verticale, ca in cazul display-ului de mobil defect, care apoi se inmultesc astfel incat jumatatea din stanga devine neagra, cealalta functionand perfect. Daca il las sa se racoreasca vreo 10 minute, revine la normal dar in juma de ora chestia se repeta. Ma puteti ajuta cu un sfat? Am incercat la un atelier dar nu i-au dat de cap. Multumesc.
Re: lc171w03
Hi kevinro40,
Salut!
I also have a Philips TV with same LCD and with same behavior. Also 30 minutes of usage it starts showing vertical red lines in the left side of LCD. After few seconds left half of screen is completly full of red and orange lines. The right half of screen still displaying images without any problem.
I think this is issue in LG.Philips' (the joint which manufacture this LCD) PCB board. I concluded it because me, you and a German guy had same issue.
Search for "Philips LC171W03-C4 / 17PF4310/01 roter senkrechter Balken" and you will find this German guy post. The edaboard's policy block me to post link since this is my first post.
Best Regards,
Alan
