LCD menu help needed / C Code
ltg
Member level 4
Member level 4
menu lcd
Would you please give some hints how to build up a logical menu with submenus in C code. This is first time I do that. I don't know how. I have three buttons used to choice and select alteratives.
Have you some exemples you can share with me? Thank you in advace!
Best Regards,
ltg
I don´t have a sample code to send to you because each case is diferent, and i don´t know what you want. Never the less the best way to make a menu, with C, is using
void main_menu (int key) {
Switch (key) {
case 0: /*code*/ submenu0 (); break;
case 1: /*code*/ submenu1(); break;
case 2: /*code*/ submenu2(); break;
default: /*error code*/ break;
and then repeat it for all the submenus.
I hope it helps you.
