pkhow
Newbie level 2
Can any one help with some code or function to interface a PIC with 4x20 LCD from different Port Bits that most functions use. I find in 4bit mode they use the UPPER Nybble or the Lower .. I need to use bit1,2,3,4 so need to shift all 4 x bits up one bit. I have tried different code to get the correct shift and masking but have had no success and can not get it to work. I am hoping someone can help or has a function where you can select different PORTbits, I would appreciate any help:-(
