LCD intefacing for 8051 Beginner with Sch & ASM File
Medtronic
Full Member level 5
Full Member level 5
Egypt
This is a full 8051 LCD 2X16 8 bit Interface
i hope it will help someone
Regards
nice work, can u explain me what is exact function of this subroutine " LCD_Com_Wrt", command write that is...
Awesome work man!
Medtronic, I am getting all screen black using your hex file.
Any suggestions?
Thanks
Dear my friend, my be you miss somthing from harsware,please reveiw your hardware and check Vcc,Gnd, and contrast pin
; This program is to test lcd display
; Demo Program Scrolling continues
;P1=data pin
;P2.0 connected to RS pin
;P2.1 connected to R/W pin
;P2.2 connected to E pin
	;call delay1
	MOV     A,#38H   ;init. LCD 2 lines,5x7 matrix
        ACALL   COMMAND       ;issue command
        MOV     A,#0EH        ;LCD on, cursor on
        MOV     A,#01H        ;clear LCD command
        MOV     A,#06H        ;shift cursor right
	MOV     A,#0C0H        ;cursor: line 1, pos. 6
        ACALL   COMMAND       ;command subroutine
        MOV     A,#'8'        ;display letter N
        ACALL   DATA_DISPLAY
        MOV     A,#'0'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'5'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'1'        ;display letter O
	ACALL   DATA_DISPLAY
        MOV     A,#'D'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'E'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'M'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'O'        ;display letter O
	ACALL   DATA_DISPLAY
	MOV     A,#083H        ;cursor: line 1, pos. 6
        MOV     A,#'4'        ;display letter N
        ACALL   DATA_DISPLAY
	CALL DELAY
        MOV     A,#'3'        ;display letter N
        ACALL   DATA_DISPLAY
	CALL DELAY
        MOV     A,#'2'        ;display letter N
        ACALL   DATA_DISPLAY
	CALL DELAY
        MOV     A,#'1'        ;display letter N
        ACALL   DATA_DISPLAY
	CALL DELAY
        MOV     A,#'0'        ;display letter N
        ACALL   DATA_DISPLAY
	CALL DELAY
        ACALL   DATA_DISPLAY
        ACALL   DATA_DISPLAY
        ACALL   DATA_DISPLAY
        ACALL   DATA_DISPLAY
	MOV     A,#' '        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'L'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'C'        ;display letter O
        ACALL   DATA_DISPLAY
	ACALL   DATA_DISPLAY
        ACALL   DATA_DISPLAY
        ACALL   DATA_DISPLAY
	MOV     A,#'I'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'S'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'P'        ;display letter O
        ACALL   DATA_DISPLAY
        ACALL   DATA_DISPLAY
	MOV     A,#'A'        ;display letter O
        ACALL   DATA_DISPLAY
	MOV     A,#'Y'        ;display letter O
        ACALL   DATA_DISPLAY
	HERE:	MOV     A,#18H        ;cursor: line 1, pos. 6
        ACALL   COMMAND
	CALL DELAY1
	lJMP HERE
	          	      ;STAY HERE
COMMAND: ACALL   READY        ;is LCD ready?
        MOV     P1,A          ;issue command code
        CLR     P2.0          ;RS=0 for command
        CLR     P2.1          ;R/W=0 to write to LCD
        SETB    P2.2          ;E=1 for H-to-L pulse
        CLR     P2.2          ;E=0 ,latch in
        RET
DATA_DISPLAY:
        MOV     P1,A          ;issue data
        SETB    P2.0          ;RS=1 for data
        CLR     P2.2          ;E=0, latch in
        RET
READY:
     SETB    P1.7             ;make P1.7 input port
     CLR     P2.0        ;RS=0 access command reg
     SETB    P2.1        ;R/W=1 read command reg
BACK:CLR     P2.2        ;E=1 for H-to-L pulse
     SETB    P2.2        ;E=0 H-to-L pulse
     JB      P1.7,BACK        ;stay until busy flag=0
     RET
delay:
mov r7, #0fh
up4: mov r6, #060h
up3: mov r5, #00h
djnz r5, $
djnz r6, up3
djnz r7, up4
ret
;-------------------delay program------------------------
DELAY1:
	  MOV  TMOD,#010H
          MOV  R3,#04H					;95
TES:      MOV  TL1,#00H					;00
          MOV  TH1,#00H					;00
          SETB TR1
T  :      JNB  TF1,T
          CLR  TR1
	  CLR  TF1
          DJNZ R3,TES
          RET
;---------------------end-------------------------------------
END
[/img]\[find datasheet of lcd  on net and connect as per it,
all the best\]
#include<reg51.h>
void lcddata(unsigned char value);
void lcdcmd(unsigned char value);
void delay( unsigned int itime);
sfr ldata=0x90;
sbit rs= P2^0;
sbit rw =P2^1;
sbit en=P2^2;
void main()
lcdcmd(0x38);
delay(50);
lcdcmd(0x0E);
delay(50);
lcdcmd(0X01);
delay(50);
lcdcmd(0X06);
delay(50);
lcdcmd(0XC0); //LINE2 POSITION 1
delay(50);
lcddata('A');
delay(50);
lcddata('N');
delay(50);
lcddata('K');
delay(50);
lcddata('I');
delay(50);
lcddata('T');
delay(50);
lcddata('-');
delay(50);
lcddata('T');
delay(50);
lcddata('h');
delay(50);
lcddata('e');
delay(50);
lcddata(' ');
delay(50);
lcddata('C');
delay(50);
lcddata('O');
delay(50);
lcddata('D');
delay(50);
lcddata('E');
delay(50);
lcddata('R');
delay(50);
ldata=value;
rs=0;
rw=0;
en=1;
delay(1);
en=0;
return;
ldata=value;
rs=1;
rw=0;
en=1;
delay(1);
en=0;
return;
unsigned int i,j;
for(i=0;i<itime;i++)
for(j=0;j<1275;j++);
//CONNECT D0-D7 TO PORT P1
//2.0 TO RO
//2.1 TO RW
//2.2 TO EN
Thats t :)
hi can tell me how i can send data from hyperterminal to lcd via 89c51 .
i have done all hardware connection as well as try some code but they r not working can u suggest me bcz i m newr for 8051.
thank you very much, i think i can learn a lot of knowledge from the passage
You have to send the data to MCU from hyperterminal and MCU will display it on LCD. Do you want C code or ASM code? Whether it is C or ASM you have to write a routine to send character to LCD and then call it as many times as the length of the string with incrementing the pointer to string.
yes i want C code .any text will show in LCD 16x2 using 89c51 with rs232
but i want code for 89c51 controller
pls help me i was facing that code problem since 1month i ddn't get any breakout
hy jay
i was downloade ur code in 89c51 via hex file.but there is no moment in lcd. i.e i was writing in hyper terminal that in not saw on lcd.
and i am using NSK devlopment board that u can see in below link.**broken link removed**
