anasimtiaz
Junior Member level 1
mplab argument out of range
im using a 16*2 lcd display module with an atmel 89c51 microcontroller. ive used the tutorial on
and used almost similar assembly language code.
however, when i run the microcontroller, the lcd module d oesnt show up any text!
the module is of 16-pins, ive connected pin 15 to +5v and pin 16 to ground, and ive used a simple voltage divider for the lcd contrast pin.
what could go wrong? if anyone can please help me out, and even look at the code on the above site (im sure thats correct, but anyways) ..... that will b appreciated
regards
regards
