title "Animate - Draw the 'Walking Man' on an LCD"
; This Code Uses the two wire LCD interface to draw a
; walking man using User Defined Characters.
; Hardware Notes:
; Reset is tied directly to Vcc and PWRT is Enabled.
; The PIC is a 16C84 Running at 4 MHz.
; PortA.0 is the Data Bit
; PortA.1 is the Clock Bit
; Shift Data:
; Bit 1 - Always High (Gate for "E")
; Bit 2 - RS Bit
; Bit 3 - LCD D4
; Bit 4 - LCD D5
; Bit 5 - LCD D6
; Bit 6 - LCD D7
; Myke Predko
; 99.04.28
LIST P=16C84, R=DEC ; 16C84 Runs at 4 MHz
errorlevel 0,-305
INCLUDE "p16c84.inc"
; Register Usage
CBLOCK 0x00C ; Start Registers at End of the Values
Dlay ; 8 Bit Delay Variable
Temp ; Temporary Value Used When Sending Out Data
NOTemp ; Temporary Value to "NybbleOutput"
Count ; Character Counter for Output
ENDC
; Define Inforation
#DEFINE Data PORTA,0
#DEFINE Clock PORTA, 1
; Macros
ClockStrobe MACRO ; Strobe the Data Bit
bsf Clock
bcf Clock
ENDM
EStrobe MACRO ; Strobe the "E" Bit
bsf Data
bcf Data
ENDM
PAGE
__CONFIG _CP_OFF & _XT_OSC & _PWRTE_ON & _WDT_OFF
; Note that the WatchDog Timer is OFF
; Demo Code, Loop Forever Toggling PA0 (Flashing the LED)
org 0
clrf PORTA
movlw 0x01C ; Enable PA0 & PA1 for Output
bsf STATUS, RP0
movwf TRISA ^ 0x080
bcf STATUS, RP0
call Dlay5 ; Wait 20 msecs before Reset
call Dlay5
call Dlay5
call Dlay5
bcf STATUS, C ; Clear Carry (Instruction Out)
movlw 0x03 ; Reset Command
call NybbleOut2 ; Send the Nybble
call Dlay5 ; Wait 5 msecs before Sending Again
EStrobe
call Dlay160 ; Wait 160 usecs before Sending the Third Time
EStrobe
bcf STATUS, C
movlw 0x02 ; Set 4 Bit Mode
call NybbleOut2
call Dlay160
movlw 0x028 ; Note that it is a 2 Line Display
call SendINS
movlw 0x008 ; Turn off the Display
call SendINS
movlw 0x001 ; Clear the Display RAM
call SendINS
call Dlay5 ; Note, Can take up to 4.1 msecs
movlw 0x006 ; Enable Cursor Move Direction
call SendINS
movlw 0x00C ; Turn the LCD Back On
call SendINS
movlw 0x040 ; Put the Cursor to the Start of CGRAM
call SendINS
movlw 0x030 ; Send 6 Characters of 8 Bytes
movwf Count ; Output the User Characters
clrf FSR
CharLoop
movf FSR, w ; Get the Offset to Output
incf FSR
call ManChar
call SendCHAR ; Output the ASCII Character
decfsz Count ; Do 48x
goto CharLoop
movlw 0x080 ; Move the Cursor Back into LCD Memory Space
call SendINS
movlw 0 ; Display the Man
call SendCHAR
movlw 'A' ; Put in "A" for Comparison
call SendCHAR
Loop ; Loop Forever when Done
call LongDlay ; Delay Between Movements
movlw 0x080 ; Send Char "1"
call SendINS
movlw 1
call SendCHAR
call LongDlay
movlw 0x080 ; Send Char "2"
call SendINS
movlw 2
call SendCHAR
call LongDlay
movlw 0x080 ; Send Char "3"
call SendINS
movlw 3
call SendCHAR
call LongDlay
movlw 0x080 ; Send Char "4"
call SendINS
movlw 4
call SendCHAR
call LongDlay
movlw 0x080 ; Send Char "5"
call SendINS
movlw 5
call SendCHAR
goto Loop
; Subroutines
ManChar ; User Characters to Display
addwf PCL ; Output the Characters
retlw 0x00E ; Character 0 - Byte 0
retlw 0x00E
retlw 0x004
retlw 0x004
retlw 0x004
retlw 0x004
retlw 0x00C
retlw 0x000
retlw 0x00E ; Character 1 - Byte 0
retlw 0x00E
retlw 0x004
retlw 0x004
retlw 0x00C
retlw 0x004
retlw 0x00C
retlw 0x000
retlw 0x00E ; Character 2 - Byte 0
retlw 0x00E
retlw 0x004
retlw 0x004
retlw 0x00A
retlw 0x01A
retlw 0x006
retlw 0x000
retlw 0x00E ; Character 3 - Byte 0
retlw 0x00E
retlw 0x004
retlw 0x004
retlw 0x006
retlw 0x009
retlw 0x019
retlw 0x000
retlw 0x00E ; Character 4 - Byte 0
retlw 0x00E
retlw 0x004
retlw 0x004
retlw 0x007
retlw 0x009
retlw 0x018
retlw 0x000
retlw 0x00E ; Character 5 - Byte 0
retlw 0x00E
retlw 0x004
retlw 0x004
retlw 0x00C
retlw 0x006
retlw 0x00C
retlw 0x000 ; Bottom Character
retlw 0x01F ; #### - Note Full Line for Bottom Character
; #### - To Show, Comment out the Previous Line
SendCHAR ; Send the Character to the LCD
movwf Temp ; Save the Temporary Value
swapf Temp, w ; Send the High Nybble
bsf STATUS, C ; RS = 1
call NybbleOut2
movf Temp, w ; Send the Low Nybble
bsf STATUS, C
call NybbleOut2
return
SendINS ; Send the Instruction to the LCD
bcf STATUS, C ; RS = 0
call NybbleOut2
bcf STATUS, C
call NybbleOut2
return
NybbleOut2 ; Send a Nybble to the LCD
movwf NOTemp ; Save the Nybble to Shift Out
swapf NOTemp ; Setup to Output to the High Part of the Byte
movlw 6 ; Clear the Shift Register
movwf Dlay
NO2Loop1
ClockStrobe
decfsz Dlay
goto NO2Loop1
movlw 5 ; Now, Shift out the Data with the "RS" Bit
movwf Dlay
bsf Data ; Put out the Gate Bit
ClockStrobe
NO2Loop2
bcf Data ; Clear the Data Bit (which is the Clock)
btfsc STATUS, C ; If the Bit to be output is a "1", Shift it Out
bsf Data
ClockStrobe
rlf NOTemp ; Shift the Next Bit into the Carry Flag
decfsz Dlay
goto NO2Loop2
EStrobe ; Strobe out the LCD Data
return
LongDlay ; Delay 200 msecs
movlw 40
movwf Count
LDLoop
call Dlay5
decfsz Count
goto LDLoop
return
Dlay160 ; Delay 160 usecs
movlw 256 - ( 160 / 4 ) ; Loop Until Carry Set
addlw 1
btfss STATUS, C
goto $-2
return
Dlay5 ; Delay 5 msecs
movlw 4 ; Set up the Delay
movwf Dlay
movlw 256 - 0x0E8
addlw 1
btfsc STATUS, Z
decfsz Dlay
goto $-3
return
end
at frist can you give me an example of GLCD with assembly?
if youre answer is no please say to me than what is RST bit on GLCD?and what I must do with that.
I must send some commands to intizaling GLCD or just I must display on it and then set Y,X and then data?(I know how can send data but I don't know what is Z address!!!)
; Breshenham's line draw for KS0108 based 128x64 LCDs
; (C) Peter Onion 2005
; Use at your own risk !
Processor 16F877
Radix DEC
EXPAND
include "p16f877.inc"
brWleF macro F,dst
subwf F,W
skpz
skpc
goto $+2 ; YUK!
goto dst
endm
#define CNTLPORT PORTB
#define CNTLTRIS TRISB
#define DATAPORT PORTD
#define DATATRIS TRISD
;; For 20Mhz use 12. Can be reduced at lower clock speeds
;; For 12.288Mhz use 5 Select on test !
#define DELAY 12
;; Definitions for bits in CNTLPORT
#define CSABIT 0
#define CSBBIT 1
#define DIBIT 2
#define RWBIT 3
#define EBIT 4
#define RESETBIT 5
;; Definitions for bits in the control word
#define INCX 0
#define INCY 1
#define DECY 2
#define SETCS 3
#define SETPAGE 4
#define FLUSH 5
#define DONE 6
#define SAVE 7
;; Macros for bit twiddling on the control interface
WSTROBE MACRO
movlw 12
movwf scratch3
decfsz scratch3,F
goto $-1
bsf CNTLPORT,EBIT ; Rising edge
IF 0
movlw 1
movwf scratch3
decfsz scratch3,F
goto $-1
ENDIF
bcf CNTLPORT,EBIT ; Falling edge
; strobes data
ENDM
RSTROBE MACRO
movlw 12
movwf scratch3
decfsz scratch3,F
goto $-1
If 0
movlw 1
movwf scratch3
decfsz scratch3,F
goto $-1
ENDIF
movf DATAPORT,W
ENDM
SETELOW MACRO
bcf CNTLPORT,EBIT
ENDM
SETW MACRO
bcf CNTLPORT,RWBIT
ENDM
SETR MACRO
bsf CNTLPORT,RWBIT
ENDM
SETD MACRO
bsf CNTLPORT,DIBIT
ENDM
SETI MACRO
bcf CNTLPORT,DIBIT
ENDM
RESETH MACRO
bsf CNTLPORT,RESETBIT
ENDM
RESETL MACRO
bcf CNTLPORT,RESETBIT
ENDM
SELA MACRO
bcf CNTLPORT,CSABIT
bsf CNTLPORT,CSBBIT
ENDM
SELB MACRO
bsf CNTLPORT,CSABIT
bcf CNTLPORT,CSBBIT
ENDM
SELBOTH MACRO
bcf CNTLPORT,CSABIT
bcf CNTLPORT,CSBBIT
ENDM
SELNONE MACRO
bsf CNTLPORT,CSABIT
bsf CNTLPORT,CSBBIT
ENDM
DATA1 UDATA
x1 res 1 ; Start ppint
y1 res 1
x2 res 1 ; End point
y2 res 1
dx res 1
dy res 1
control res 1
length res 1
dec res 1
d res 1
aa res 1
bb res 1
temp res 1
cachestart res 1
currentbyte res 1
cachelength res 1
count res 1
pageNo res 1
AA res 1
BB res 1
xpos res 1
ypos res 1
ctlCode res 1 ; bits
temp1 res 1
pixelbit res 1
;; delay res 1
;; A cache that hold one "page" of pixels
CacheRam UDATA
cache res 64
;; Scratch registers in shared bank. DO not assume they
;; are preserved by any subroutines.
extern scratch1,scratch2,scratch3,scratch4
GLOBAL x1,y1,x2,y2
line CODE
;; Clear the LCD
clearLCD:
clrf scratch1 ; set page number to zero
banksel CNTLPORT
SELBOTH ; Write to both halves together
SETW
clrloop:
SETI
movf scratch1,W
addlw 0xB8 ; set page number
movwf DATAPORT
WSTROBE
movlw 0x40 ; set X address to 0
movwf DATAPORT
WSTROBE
movlw 64
movwf scratch2 ; counter
SETW
SETD
movlw 0x0 ; clear to OFF
movwf DATAPORT
clrloop1:
WSTROBE
decfsz scratch2,F
goto clrloop1
incf scratch1,F ; loop until page == 8
btfss scratch1,3
goto clrloop
SETI
SELNONE
return
;; Write used part of cache back to the LCD
flushcache:
BANKSEL CNTLPORT
BANKISEL cache ; set up for indirect cahce access
movlw cache
movwf FSR
banksel cachelength
movf cachelength,W
movwf scratch1 ; hold the counter
banksel CNTLPORT
SETI
SETW
BANKSEL DATATRIS ; reset portd to output
movlw 0x00
movwf DATATRIS
banksel cachestart
movlw 0x40 ; set y address to first used
addwf cachestart,W ; byte in the cache
banksel DATAPORT
movwf DATAPORT
WSTROBE
SETD ; data
SETW ; write
flushloop:
movlw DELAY
movwf scratch2
decfsz scratch2,F
goto $-1
movf INDF,W ; read from the cache
movwf DATAPORT
; strobes data
incf FSR,F
decfsz scratch1,F
goto flushloop
return
linedraw:
banksel ctlCode
clrf ctlCode
clrf control
comf y1,F ; Make y = 0 the bottom rather
comf y2,F ; than the top
movf x1,W ; check moving left to right
subwf x2,W ; and workout dx
skpnc
goto ld1
sublw 0
movwf temp
movf x1,W ; swap end points so left to right
movwf temp1
movf x2,W
movwf x1
movf temp1,W
movwf x2
movf y1,W
movwf temp1
movf y2,W
movwf y1
movf temp1,W
movwf y2
movf temp,W
ld1
movwf dx ; dx = |x1 - x2|
movf y1,W
subwf y2,W
skpnc
goto ld2
sublw 0
bsf ctlCode,0 ; Going Up or Down
ld2
movwf dy ; dy = |y1 - y2|
movf dy,W ; test if steep or shallow line
subwf dx,W
skpnc
goto ld3
movf dx,W ; swap to make shallow
movwf temp
movf dy,W
movwf dx
movf temp,W
movwf dy
bsf ctlCode,1 ; set "steep flag"
ld3
clrf dec
bcf STATUS,C
rrf dx,W ; W = dx >> 1
rlf dec,F ; dec = dx & 1
subwf dy,W ; W = dy - (dx >> 1)
movwf d ; d = W
movf dx,W
subwf dy,W
movwf AA ; A = dy -dx
movf dy,W
movwf BB ; B = dy
movf AA,W
subwf dec,F ; dec -= A
subwf d,F ; d -= A
movf dx,W
sublw 0
movwf AA ; A = -dx
movf x1,W ; set up for looping
movwf xpos
movf y1,W
movwf ypos
movf dx,W
movwf length
clrf control ; set the inital actions to take
bsf control,SETCS ; setup the Chip Selects
bsf control,SETPAGE ; set the page number
bsf control,SAVE ;
movf ypos,W ; Set correct bit in pixelbit
andlw 0x7 ; for the y position
addlw 0x1
movwf temp
clrf pixelbit
bsf STATUS,C
setyloop:
rlf pixelbit,F
decfsz temp,F
goto setyloop
;; loop back here if step over to right hand side
setcs: banksel control
btfss control,SETCS
goto pageSet
bcf control,SETCS
btfsc xpos,6 ; set correct Chip select
goto setcs1
banksel CNTLPORT
SELA
goto pageSet
setcs1: banksel CNTLPORT
SELB
pageSet:banksel control
btfss control,SETPAGE
goto initcache
movf ypos,W ; set y page address in controler
movwf pageNo
rrf pageNo,F
rrf pageNo,F
rrf pageNo,F
movlw 0x7
andwf pageNo,F
movf pageNo,W
addlw 0xB8
banksel DATAPORT
movwf DATAPORT
SETI
SETW
WSTROBE
initcache:
bankisel cache
banksel cachelength
clrf cachelength ; initialise the cache
movlw cache
movwf FSR
movf xpos,W
andlw 0x3F
movwf cachestart
movlw 0x40 ; set x address
addwf cachestart,W
banksel DATAPORT
movwf DATAPORT
WSTROBE
clrf DATAPORT ; prepare to read from controler
BANKSEL DATATRIS
movlw 0xFF
movwf DATATRIS
BANKSEL DATAPORT
SETD ; data
SETR ; read
RSTROBE ; Dummy read
readbyte:
banksel control
btfss control,SAVE
goto dontread
banksel DATAPORT
RSTROBE ; read the byte
banksel currentbyte
movwf currentbyte
dontread:
movf pixelbit,W ; set the bit
iorwf currentbyte,F
btfsc control,DONE ; test end flag
goto alldone
clrf control ; reset all the flags
;; DANGER DANGER..... Check for page boundry !!
here: banksel ctlCode
movlw high $
movwf PCLATH ; page
movf ctlCode,W
andlw 0x7
addwf PCL,F
goto code0
goto code1
goto code2
goto code3
code0:
movf d,W
brWleF dec,code01
movf AA,W
addwf d,F
bsf control,INCY
code01: movf BB,W
addwf d,F
bsf control,INCX
goto common
code1: movf d,W
brWleF dec,code11
movf AA,W
addwf d,F
bsf control,DECY
code11: movf BB,W
addwf d,F
bsf control,INCX
goto common
code2:
movf d,W
brWleF dec,code21
movf AA,W
addwf d,F
bsf control,INCX
code21: movf BB,W
addwf d,F
bsf control,INCY
goto common
code3: movf d,W
brWleF dec,code31
movf AA,W
addwf d,F
bsf control,INCX
code31: movf BB,W
addwf d,F
bsf control,DECY
goto common
common:
decf length,F
skpnz
bsf control,DONE
btfss control,INCX ; did we move to the right ?
goto checkINCY
bsf control,SAVE
movf xpos,W ; increment X
incf xpos,F
xorwf xpos,W
movwf temp1
btfss temp1,6 ; test for left-to-right change
goto checkINCY
bsf control,FLUSH ; set flush
bsf control,SETCS ; set setCS
bsf control,SETPAGE
checkINCY:
btfss control,INCY ; did we move down ?
goto checkDECY
incf ypos,F
bcf STATUS,C
rlf pixelbit,F ; move bit
btfss STATUS,C ; if carry set, we ned to move to next bank
goto checksave
rlf pixelbit,F
bsf control,SETPAGE
bsf control,SAVE
bsf control,FLUSH
goto checksave
checkDECY:
btfss control,DECY ; did we move up ?
goto checksave
decf ypos,F
bcf STATUS,C
rrf pixelbit,F
btfss STATUS,C
goto checksave
rrf pixelbit,F
bsf control,SETPAGE
bsf control,SAVE
bsf control,FLUSH
goto checksave
checksave: ; do we need to save byte to cache ?
btfss control,SAVE
goto checkflush
movf currentbyte,W ; write byte to cache
movwf INDF
incf FSR,F
incf cachelength,F
checkflush: ; do we need to flush the cache ?
btfss control,FLUSH
goto readbyte
call flushcache
goto setcs
alldone: ; write endpoint and flush cache
movf currentbyte,W
movwf INDF
incf FSR,F
incf cachelength,F
call flushcache
return
[COLOR="#FF8C00"]initGRLCD:
banksel DATATRIS
clrf DATATRIS
clrf CNTLTRIS
banksel DATAPORT
RESETL ; 5 XX0XXXXX
SELBOTH ; 0 1 XX0XXX00
SETELOW ; 4 XX00XX00
SETI ; 2 XX00X000
SETW ; 3 XX000000
RESETH ; XX100000
movlw 0x3F ; Display ON
movwf DATAPORT
movlw 9
movwf scratch1
decfsz scratch1,F
goto $-1
WSTROBE
movlw 0x40 ; set x address to 0
movwf DATAPORT
WSTROBE
movlw 0xBF ; set page to 0
movwf DATAPORT
WSTROBE
movlw 0xC0 ; set display start line to 0
movwf DATAPORT
WSTROBE
return[/COLOR]
GLOBAL linedraw,initGRLCD,clearLCD
END
; Created by LCDtrigtable360.c
Processor 16F877
trig CODE
GLOBAL xtable,ytable
xtable:
DW 0x40
DW 0x40
DW 0x41
DW 0x42
DW 0x43
DW 0x43
DW 0x44
DW 0x45
DW 0x46
DW 0x47
DW 0x47
DW 0x48
DW 0x49
DW 0x4A
DW 0x4B
DW 0x4B
DW 0x4C
DW 0x4D
DW 0x4E
DW 0x4E
DW 0x4F
DW 0x50
DW 0x51
DW 0x51
DW 0x52
DW 0x53
DW 0x54
DW 0x54
DW 0x55
DW 0x56
DW 0x56
DW 0x57
DW 0x58
DW 0x58
DW 0x59
DW 0x5A
DW 0x5A
DW 0x5B
DW 0x5C
DW 0x5C
DW 0x5D
DW 0x5E
DW 0x5E
DW 0x5F
DW 0x5F
DW 0x60
DW 0x60
DW 0x61
DW 0x62
DW 0x62
DW 0x63
DW 0x63
DW 0x64
DW 0x64
DW 0x65
DW 0x65
DW 0x65
DW 0x66
DW 0x66
DW 0x67
DW 0x67
DW 0x68
DW 0x68
DW 0x68
DW 0x69
DW 0x69
DW 0x69
DW 0x6A
DW 0x6A
DW 0x6A
DW 0x6B
DW 0x6B
DW 0x6B
DW 0x6B
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6B
DW 0x6B
DW 0x6B
DW 0x6B
DW 0x6A
DW 0x6A
DW 0x6A
DW 0x69
DW 0x69
DW 0x69
DW 0x68
DW 0x68
DW 0x68
DW 0x67
DW 0x67
DW 0x66
DW 0x66
DW 0x65
DW 0x65
DW 0x65
DW 0x64
DW 0x64
DW 0x63
DW 0x63
DW 0x62
DW 0x62
DW 0x61
DW 0x60
DW 0x60
DW 0x5F
DW 0x5F
DW 0x5E
DW 0x5E
DW 0x5D
DW 0x5C
DW 0x5C
DW 0x5B
DW 0x5A
DW 0x5A
DW 0x59
DW 0x58
DW 0x58
DW 0x57
DW 0x56
DW 0x56
DW 0x55
DW 0x54
DW 0x54
DW 0x53
DW 0x52
DW 0x51
DW 0x51
DW 0x50
DW 0x4F
DW 0x4E
DW 0x4E
DW 0x4D
DW 0x4C
DW 0x4B
DW 0x4B
DW 0x4A
DW 0x49
DW 0x48
DW 0x47
DW 0x47
DW 0x46
DW 0x45
DW 0x44
DW 0x43
DW 0x43
DW 0x42
DW 0x41
DW 0x40
DW 0x40
DW 0x3F
DW 0x3E
DW 0x3D
DW 0x3C
DW 0x3C
DW 0x3B
DW 0x3A
DW 0x39
DW 0x38
DW 0x38
DW 0x37
DW 0x36
DW 0x35
DW 0x34
DW 0x34
DW 0x33
DW 0x32
DW 0x31
DW 0x31
DW 0x30
DW 0x2F
DW 0x2E
DW 0x2E
DW 0x2D
DW 0x2C
DW 0x2B
DW 0x2B
DW 0x2A
DW 0x29
DW 0x29
DW 0x28
DW 0x27
DW 0x27
DW 0x26
DW 0x25
DW 0x25
DW 0x24
DW 0x23
DW 0x23
DW 0x22
DW 0x21
DW 0x21
DW 0x20
DW 0x20
DW 0x1F
DW 0x1F
DW 0x1E
DW 0x1D
DW 0x1D
DW 0x1C
DW 0x1C
DW 0x1B
DW 0x1B
DW 0x1A
DW 0x1A
DW 0x1A
DW 0x19
DW 0x19
DW 0x18
DW 0x18
DW 0x17
DW 0x17
DW 0x17
DW 0x16
DW 0x16
DW 0x16
DW 0x15
DW 0x15
DW 0x15
DW 0x14
DW 0x14
DW 0x14
DW 0x14
DW 0x13
DW 0x13
DW 0x13
DW 0x13
DW 0x13
DW 0x13
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x12
DW 0x13
DW 0x13
DW 0x13
DW 0x13
DW 0x13
DW 0x13
DW 0x14
DW 0x14
DW 0x14
DW 0x14
DW 0x15
DW 0x15
DW 0x15
DW 0x16
DW 0x16
DW 0x16
DW 0x17
DW 0x17
DW 0x17
DW 0x18
DW 0x18
DW 0x19
DW 0x19
DW 0x1A
DW 0x1A
DW 0x1A
DW 0x1B
DW 0x1B
DW 0x1C
DW 0x1C
DW 0x1D
DW 0x1D
DW 0x1E
DW 0x1F
DW 0x1F
DW 0x20
DW 0x20
DW 0x21
DW 0x21
DW 0x22
DW 0x23
DW 0x23
DW 0x24
DW 0x25
DW 0x25
DW 0x26
DW 0x27
DW 0x27
DW 0x28
DW 0x29
DW 0x29
DW 0x2A
DW 0x2B
DW 0x2B
DW 0x2C
DW 0x2D
DW 0x2E
DW 0x2E
DW 0x2F
DW 0x30
DW 0x31
DW 0x31
DW 0x32
DW 0x33
DW 0x34
DW 0x34
DW 0x35
DW 0x36
DW 0x37
DW 0x38
DW 0x38
DW 0x39
DW 0x3A
DW 0x3B
DW 0x3C
DW 0x3C
DW 0x3D
DW 0x3E
DW 0x3F
DW 0x3F
DW 0x40
DW 0x41
DW 0x42
DW 0x43
DW 0x43
DW 0x44
DW 0x45
DW 0x46
DW 0x47
DW 0x47
DW 0x48
DW 0x49
DW 0x4A
DW 0x4B
DW 0x4B
DW 0x4C
DW 0x4D
DW 0x4E
DW 0x4E
DW 0x4F
DW 0x50
DW 0x51
DW 0x51
DW 0x52
DW 0x53
DW 0x54
DW 0x54
DW 0x55
DW 0x56
DW 0x56
DW 0x57
DW 0x58
DW 0x58
DW 0x59
DW 0x5A
DW 0x5A
DW 0x5B
DW 0x5C
DW 0x5C
DW 0x5D
DW 0x5E
DW 0x5E
DW 0x5F
DW 0x5F
DW 0x60
DW 0x60
DW 0x61
DW 0x62
DW 0x62
DW 0x63
DW 0x63
DW 0x64
DW 0x64
DW 0x65
DW 0x65
DW 0x65
DW 0x66
DW 0x66
DW 0x67
DW 0x67
DW 0x68
DW 0x68
DW 0x68
DW 0x69
DW 0x69
DW 0x69
DW 0x6A
DW 0x6A
DW 0x6A
DW 0x6B
DW 0x6B
DW 0x6B
DW 0x6B
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6C
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
DW 0x6D
ytable:
DW 0x20
DW 0x20
DW 0x21
DW 0x21
DW 0x22
DW 0x22
DW 0x23
DW 0x23
DW 0x24
DW 0x24
DW 0x25
DW 0x25
DW 0x26
DW 0x26
DW 0x27
DW 0x28
DW 0x28
DW 0x29
DW 0x29
DW 0x2A
DW 0x2A
DW 0x2B
DW 0x2B
DW 0x2C
DW 0x2C
DW 0x2D
DW 0x2D
DW 0x2E
DW 0x2E
DW 0x2F
DW 0x2F
DW 0x2F
DW 0x30
DW 0x30
DW 0x31
DW 0x31
DW 0x32
DW 0x32
DW 0x33
DW 0x33
DW 0x33
DW 0x34
DW 0x34
DW 0x35
DW 0x35
DW 0x35
DW 0x36
DW 0x36
DW 0x37
DW 0x37
DW 0x37
DW 0x38
DW 0x38
DW 0x38
DW 0x39
DW 0x39
DW 0x39
DW 0x39
DW 0x3A
DW 0x3A
DW 0x3A
DW 0x3B
DW 0x3B
DW 0x3B
DW 0x3B
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3F
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3B
DW 0x3B
DW 0x3B
DW 0x3B
DW 0x3A
DW 0x3A
DW 0x3A
DW 0x39
DW 0x39
DW 0x39
DW 0x39
DW 0x38
DW 0x38
DW 0x38
DW 0x37
DW 0x37
DW 0x37
DW 0x36
DW 0x36
DW 0x35
DW 0x35
DW 0x35
DW 0x34
DW 0x34
DW 0x33
DW 0x33
DW 0x33
DW 0x32
DW 0x32
DW 0x31
DW 0x31
DW 0x30
DW 0x30
DW 0x2F
DW 0x2F
DW 0x2F
DW 0x2E
DW 0x2E
DW 0x2D
DW 0x2D
DW 0x2C
DW 0x2C
DW 0x2B
DW 0x2B
DW 0x2A
DW 0x2A
DW 0x29
DW 0x29
DW 0x28
DW 0x28
DW 0x27
DW 0x26
DW 0x26
DW 0x25
DW 0x25
DW 0x24
DW 0x24
DW 0x23
DW 0x23
DW 0x22
DW 0x22
DW 0x21
DW 0x21
DW 0x20
DW 0x20
DW 0x1F
DW 0x1E
DW 0x1E
DW 0x1D
DW 0x1D
DW 0x1C
DW 0x1C
DW 0x1B
DW 0x1B
DW 0x1A
DW 0x1A
DW 0x19
DW 0x19
DW 0x18
DW 0x17
DW 0x17
DW 0x16
DW 0x16
DW 0x15
DW 0x15
DW 0x14
DW 0x14
DW 0x13
DW 0x13
DW 0x12
DW 0x12
DW 0x11
DW 0x11
DW 0x10
DW 0x10
DW 0x10
DW 0x0F
DW 0x0F
DW 0x0E
DW 0x0E
DW 0x0D
DW 0x0D
DW 0x0C
DW 0x0C
DW 0x0C
DW 0x0B
DW 0x0B
DW 0x0A
DW 0x0A
DW 0x0A
DW 0x09
DW 0x09
DW 0x08
DW 0x08
DW 0x08
DW 0x07
DW 0x07
DW 0x07
DW 0x06
DW 0x06
DW 0x06
DW 0x06
DW 0x05
DW 0x05
DW 0x05
DW 0x04
DW 0x04
DW 0x04
DW 0x04
DW 0x03
DW 0x03
DW 0x03
DW 0x03
DW 0x03
DW 0x02
DW 0x02
DW 0x02
DW 0x02
DW 0x02
DW 0x02
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x01
DW 0x02
DW 0x02
DW 0x02
DW 0x02
DW 0x02
DW 0x02
DW 0x03
DW 0x03
DW 0x03
DW 0x03
DW 0x03
DW 0x04
DW 0x04
DW 0x04
DW 0x04
DW 0x05
DW 0x05
DW 0x05
DW 0x06
DW 0x06
DW 0x06
DW 0x06
DW 0x07
DW 0x07
DW 0x07
DW 0x08
DW 0x08
DW 0x08
DW 0x09
DW 0x09
DW 0x0A
DW 0x0A
DW 0x0A
DW 0x0B
DW 0x0B
DW 0x0C
DW 0x0C
DW 0x0C
DW 0x0D
DW 0x0D
DW 0x0E
DW 0x0E
DW 0x0F
DW 0x0F
DW 0x10
DW 0x10
DW 0x10
DW 0x11
DW 0x11
DW 0x12
DW 0x12
DW 0x13
DW 0x13
DW 0x14
DW 0x14
DW 0x15
DW 0x15
DW 0x16
DW 0x16
DW 0x17
DW 0x17
DW 0x18
DW 0x19
DW 0x19
DW 0x1A
DW 0x1A
DW 0x1B
DW 0x1B
DW 0x1C
DW 0x1C
DW 0x1D
DW 0x1D
DW 0x1E
DW 0x1E
DW 0x1F
DW 0x1F
DW 0x20
DW 0x21
DW 0x21
DW 0x22
DW 0x22
DW 0x23
DW 0x23
DW 0x24
DW 0x24
DW 0x25
DW 0x25
DW 0x26
DW 0x26
DW 0x27
DW 0x28
DW 0x28
DW 0x29
DW 0x29
DW 0x2A
DW 0x2A
DW 0x2B
DW 0x2B
DW 0x2C
DW 0x2C
DW 0x2D
DW 0x2D
DW 0x2E
DW 0x2E
DW 0x2F
DW 0x2F
DW 0x2F
DW 0x30
DW 0x30
DW 0x31
DW 0x31
DW 0x32
DW 0x32
DW 0x33
DW 0x33
DW 0x33
DW 0x34
DW 0x34
DW 0x35
DW 0x35
DW 0x35
DW 0x36
DW 0x36
DW 0x37
DW 0x37
DW 0x37
DW 0x38
DW 0x38
DW 0x38
DW 0x39
DW 0x39
DW 0x39
DW 0x39
DW 0x3A
DW 0x3A
DW 0x3A
DW 0x3B
DW 0x3B
DW 0x3B
DW 0x3B
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3C
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3D
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3E
DW 0x3F
END
shares this code:
Processor 16F877
Radix DEC
EXPAND
EXTERN initGRLCD,clearLCD,linedraw
EXTERN x1,y1,x2,y2
EXTERN xtable,ytable
shared UDATA_SHR
FSR_TEMP res 1
W_TEMP res 1
STATUS_TEMP res 1
scratch1 res 1 ; work space
scratch2 res 1
scratch3 res 1
scratch4 res 1
scratch5 res 1
GLOBAL scratch1,scratch2,scratch3
UDATA
count res 1
xx res 1
yy res 1
angleL res 1
angleH res 1
_ResetVector set 0x00
ORG _ResetVector
movlw high Start
movwf PCLATH
goto Start
application CODE
Start:
pagesel initGRLCD
call initGRLCD
pagesel clearLCD
call clearLCD
movlw 0x0
movwf xx
movlw 0x3F
movwf yy
movlw 21
movwf count
loop:
movf xx,W
movwf scratch1
movf yy,W
movwf scratch2
banksel x1
movlw 0
movwf x1
movf scratch2,W
movwf y1
movf scratch1,W
movwf x2
movlw 0x0
movwf y2
pagesel linedraw
call linedraw
banksel xx
movlw 6
addwf xx,F
movlw 3
subwf yy,F
clrf scratch1
clrf scratch2
movlw 0x1
movwf scratch3
decfsz scratch1,F
goto $-1
decfsz scratch2,F
goto $-3
decfsz scratch3,F
goto $-5
decfsz count,F
goto loop
pagesel clearLCD
call clearLCD
loop3:
banksel angleL
clrf angleL
clrf angleH
movlw 60
movwf count
loop2:
pagesel clearLCD
call clearLCD
pagesel $
banksel x1
movlw 0x40
movwf x1
movlw 0x20
movwf y1
call xsinlookup
banksel x2
andlw 0x7F
movwf x2
call ycoslookup
banksel y2
andlw 0x3F
movwf y2
pagesel linedraw
call linedraw
pagesel $
clrf scratch1
clrf scratch2
movlw 0x4
movwf scratch3
decfsz scratch1,F
goto $-1
decfsz scratch2,F
goto $-3
decfsz scratch3,F
goto $-5
banksel angleL
movlw 6
addwf angleL,F
btfsc STATUS,C
incf angleH,F
decfsz count,F
goto loop2
goto loop3
commonlook:
banksel EEADRH
movwf EEADRH
movf scratch1,W
banksel EEADR
movwf EEADR
banksel EECON1
bsf EECON1 & 0x7F,EEPGD
bsf EECON1 & 0x7F,RD
nop
nop
banksel EEDATA
movf EEDATA,W
banksel angleL
return
xsinlookup:
banksel angleL
movf angleL,W
addlw low xtable
movwf scratch1
movlw high xtable
btfsc STATUS,C
addlw 1
addwf angleH,W
goto commonlook
xcoslookup:
banksel angleL
clrf scratch2
movf angleL,W
addlw 90
movwf scratch1
btfsc STATUS,C
incf scratch2,F
addlw low xtable
movwf scratch1
btfsc STATUS,C
incf scratch2,F
movlw high xtable
addwf scratch2,W
addwf angleH,W
goto commonlook
ysinlookup:
banksel angleL
movf angleL,W
addlw low ytable
movwf scratch1
movlw high ytable
btfsc STATUS,C
addlw 1
addwf angleH,W
goto commonlook
ycoslookup
banksel angleL
clrf scratch2
movf angleL,W
addlw 90
movwf scratch1
btfsc STATUS,C
incf scratch2,F
addlw low ytable
movwf scratch1
btfsc STATUS,C
incf scratch2,F
movlw high ytable
addwf scratch2,W
addwf angleH,W
goto commonlook
END
about LCD(CGRAM):
I can intizaling LCD in assembly and send commands and characters to it.for save data on CGRAM I must send CGRAM address:
movlw 0x40
call LCD_CMD ;LCD_CMD --> send lcd commands
well,now I wanna send my character to save it in CGRAM and then show it on LCD.I understand that if I use this code I can show my character on LCD which is saved in
CGRAM:
movlw 1
call LCD_CHR ;LCD_CHR --> send character to lcd
here,what is 1 ?it was in youre code.thanks
