LCD 4X40 with Two enable Pin
Fragrance
East Of Earth
Hi
I need CG ram OR Dram address for row1 row 2 row 3 and row 4 colud some one help me with this
regards
Fragrance
Do you have the full model # of the LCD ? Who makes it ?
The 40x4 LCD is just like two 20x4 LCDs put side by side with two separate HD44780 controllers. While there may be varients depending on manufacturer, What I would do is the use the two controllers independently as 20x4 and see what goes where. It should not be difficult to find out.
i am new to lcd's ,i am at the first year of electrical engineerng
is it posible to introduce some sites to me for getting infomation
hank you
Do not start a new topic within a topic!!!
If you have a question start a new thread instead!!!
/davorin
hi
i have found the data sheet for my display i just want to know what will the cgram address for the line 1 and 2,3 ,4 if some one help with this
i know it has two controller one releated to e1 and other with e2
The addresses for cgram are usually 8 - 5x8dots from address 0 of the cgram, selected by register.
Are you sure you do not mean ddram, which would be:
line 1 (0x00) Chip Select 1
line 2 (0x40) Chip Select 1
line 3 (0x00) Chip Select 2
line 4 (0x40) Chip Select 2
Sorry if I do not understand your question.
Regards
NTFreak
