[SOLVED] LCD 4 bit mode interfacing
hemnath
Advanced Member level 3
Chennai
Hardware: PIC18F2520
Microcontroller pins B0 to B3 connected LCD DB4 to DB7;
A2 connected to RS
A1 connected to Enable
CCS C compiler program:
#include "18F2520.h"
#fuses  INTRC_IO
#use delay(clock=4000000)
#define EN     PIN_A1
#define RS     PIN_A2
void lcd_init();
void lcd_cmd(unsigned char );
void lcd_data(unsigned char );
void disp_cmd(unsigned char );
void disp_data(unsigned char );
void main()
   delay_ms(100);
   lcd_init();
   delay_ms(100);
   while(1)
      disp_cmd(0x80);
      printf(disp_data, "TESTING ");
      delay_ms(100);
void lcd_init()
   disp_cmd(0x02);      // To initialize LCD in 4-bit mode.
   disp_cmd(0x20);      // To initialize LCD in 1 lines, 5x7 dots and 4bit mode.
   disp_cmd(0x0C);
   disp_cmd(0x01);
   disp_cmd(0x06);
   disp_cmd(0x80);
void lcd_cmd(unsigned char c)
   output_b(c);
   output_low(RS);
   output_high(EN);
   delay_ms(15);
   output_low(EN);
void lcd_data(unsigned char z)
   output_b(z);
   output_high(RS);
   output_high(EN);
   delay_ms(15);
   output_low(EN);
void disp_cmd(unsigned char cmd_value)
   unsigned char cmd_value1;
   cmd_value1 = ((cmd_value>>4) & 0x0F);   // Shift 4-bit and mask
   lcd_cmd(cmd_value1);               // Send to LCD
   cmd_value1=(cmd_value & 0x0F);
void disp_data(unsigned char data_value)
   unsigned char data_value1;
   data_value1 = ((data_value>>4) & 0x0F);
   lcd_data(data_value1);
   data_value1=(data_value & 0x0F);
But the display shows nothing. Voltages are +5V. Please help .
LCD drive voltage pin to adjust contrast is not connected.
Klaus
PIN 3 is connected to potentiometer. When Checking with 4 bit mode using PINS B4 to B7 it is working. But when I use B0 to B3 it is not working.
