[SOLVED] lcd 4 bit error .. trying to interfcing with 8051 in single port
thannara123
Advanced Member level 5
.............................main...................................
[FONT=Courier New][COLOR=#339933]#include <REGX51.H>[/COLOR][/FONT]
[FONT=Courier New][COLOR=#339933]#define LCDPORT P2[/COLOR][/FONT]
[FONT=Courier New]sbit RS = LCDPORT ^ [COLOR=#cc66cc]2[/COLOR];[/FONT]
[FONT=Courier New]sbit E = LCDPORT ^ [COLOR=#cc66cc]3[/COLOR];[/FONT]
[FONT=Courier New][COLOR=#339933]#include "lcd.h"[/COLOR][/FONT]
[FONT=Courier New][COLOR=#993333]void[/COLOR] main[COLOR=#66cc66]([/COLOR][COLOR=#66cc66])[/COLOR][/FONT]
[FONT=Courier New][COLOR=#66cc66]{[/COLOR][/FONT]
[FONT=Courier New] [/FONT]
[FONT=Courier New]    lcd_init[COLOR=#66cc66]([/COLOR][COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]    lcd_cmd[COLOR=#66cc66]([/COLOR]0x80[COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]    lcd_data[COLOR=#66cc66]([/COLOR][COLOR=#cc66cc]1[/COLOR][COLOR=#66cc66])[/COLOR];		[COLOR=#808080][I]// just send "1" to lcd to display ;[/I][/COLOR][/FONT]
[FONT=Courier New]    [COLOR=#b1b100]while[/COLOR] [COLOR=#66cc66]([/COLOR][COLOR=#cc66cc]1[/COLOR][COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New][COLOR=#66cc66]}
[/COLOR]..................................................................................................
 ........................lcd.h.......................
[FONT=Courier New][COLOR=#339933]#include"delay.h"[/COLOR][/FONT]
[FONT=Courier New][COLOR=#993333]void[/COLOR] latch[COLOR=#66cc66]([/COLOR][COLOR=#993333]void[/COLOR][COLOR=#66cc66])[/COLOR][/FONT]
[FONT=Courier New]    E = [COLOR=#cc66cc]1[/COLOR];[/FONT]
[FONT=Courier New]    delay[COLOR=#66cc66]([/COLOR][COLOR=#cc66cc]1[/COLOR][COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]    E = [COLOR=#cc66cc]0[/COLOR];[/FONT]
[FONT=Courier New][COLOR=#66cc66]}[/COLOR][/FONT]
[FONT=Courier New][COLOR=#993333]void[/COLOR] lcd_cmd[COLOR=#66cc66]([/COLOR][COLOR=#993333]unsigned[/COLOR] [COLOR=#993333]char[/COLOR] c[COLOR=#66cc66])[/COLOR][/FONT]
[FONT=Courier New]    RS = [COLOR=#cc66cc]0[/COLOR];[/FONT]
[FONT=Courier New]    delay[COLOR=#66cc66]([/COLOR][COLOR=#cc66cc]10[/COLOR][COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]    LCDPORT = c & 0xf0;[/FONT]
[FONT=Courier New]    latch[COLOR=#66cc66]([/COLOR][COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]    c = [COLOR=#66cc66]([/COLOR]c << [COLOR=#cc66cc]4[/COLOR][COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New][COLOR=#993333]void[/COLOR] lcd_data[COLOR=#66cc66]([/COLOR][COLOR=#993333]unsigned[/COLOR] [COLOR=#993333]char[/COLOR] c[COLOR=#66cc66])[/COLOR][/FONT]
[FONT=Courier New]    RS = [COLOR=#cc66cc]1[/COLOR];[/FONT]
[FONT=Courier New][COLOR=#993333]void[/COLOR] lcd_init[COLOR=#66cc66]([/COLOR][COLOR=#66cc66])[/COLOR][/FONT]
[FONT=Courier New]    lcd_cmd[COLOR=#66cc66]([/COLOR]0x30[COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]    lcd_cmd[COLOR=#66cc66]([/COLOR]0x28[COLOR=#66cc66])[/COLOR];		[COLOR=#808080][I]// Function set (4-bit interface, 2 lines, 5*7Pixels)[/I][/COLOR][/FONT]
[FONT=Courier New]    lcd_cmd[COLOR=#66cc66]([/COLOR]0x0c[COLOR=#66cc66])[/COLOR];		[COLOR=#808080][I]// Make cursorinvisible[/I][/COLOR][/FONT]
[FONT=Courier New]    lcd_cmd[COLOR=#66cc66]([/COLOR]0x6[COLOR=#66cc66])[/COLOR];		[COLOR=#808080][I]// Set entry Mode(auto increment of cursor)[/I][/COLOR][/FONT]
[/COLOR].......................................................................................................[COLOR=#66cc66]
[/COLOR]
................................ delay.h[COLOR=#66cc66][/COLOR].........................[COLOR=#66cc66]
[/COLOR]
[/FONT]
[LIST=1]
[*][FONT=Courier New][COLOR=#993333]void[/COLOR] delay[COLOR=#66cc66]([/COLOR][COLOR=#993333]unsigned[/COLOR] [COLOR=#993333]int[/COLOR] j[COLOR=#66cc66])[/COLOR][/FONT]
[*][FONT=Courier New][COLOR=#66cc66]{[/COLOR][/FONT]
[*][FONT=Courier New]    [COLOR=#993333]unsigned[/COLOR] [COLOR=#993333]int[/COLOR] i = [COLOR=#cc66cc]0[/COLOR];[/FONT]
[*][FONT=Courier New]    [COLOR=#b1b100]for[/COLOR] [COLOR=#66cc66]([/COLOR]; i < j; i++[COLOR=#66cc66])[/COLOR];[/FONT]
[*][FONT=Courier New][COLOR=#66cc66]}[/COLOR][/FONT]
[/FONT]
[/LIST]
[COLOR=#66cc66]
[/COLOR]
[/FONT]
I cant test because delay.h missing......
Which version of Keil compiler you have? Problems is with simulation or ...?
printf("Greetings,")
main()
{No delay.h ???}
#include<Good Luck.h> // :p
Stupid questions are better than stupid mistakes.
Make every stupid/silly mistake you can, in that way you will learn more.
I am attaching the whole project file with Proteus
  • 4bit with single port.rar
sir did you look the data masking and shifiting section .I have some doubts there ?
is there correct sending MSB and LSB ?
Code C - [expand]
LCDPORT = c & 0xf0;
latch();
c = (c << 4);
LCDPORT = c & 0xf0;
Say c = 0xAB
c & 0xF0 = 0A0 which is sent to D4 to D7
c = c << 4 makes c = 0xB0 and
c & 0xF0 becomes 0xB0 which is sent to D4 to D7
so, c = c<< 4 is enough, you don't need c & 0xF0
Code C - [expand]
LCDPORT = c & 0xf0;
latch();
c = (c << 4);
LCDPORT = c;
I will check out sir and will the result soon
thanks again .
Post your whole code and the error window!!!
there no error .. now I can debug (due to separate header file i cant debug now okay ).
after build up ,in Proteus there is no output . blank
[FONT=Courier New][COLOR=#993333]void[/COLOR] delay[COLOR=#66cc66]([/COLOR][COLOR=#993333]unsigned[/COLOR] [COLOR=#993333]int[/COLOR] itime[COLOR=#66cc66])[/COLOR][/FONT]
[FONT=Courier New]    [COLOR=#993333]unsigned[/COLOR] [COLOR=#993333]int[/COLOR] i, j;[/FONT]
[FONT=Courier New]    [COLOR=#b1b100]for[/COLOR] [COLOR=#66cc66]([/COLOR]i = [COLOR=#cc66cc]0[/COLOR]; i < itime; i++[COLOR=#66cc66])[/COLOR][/FONT]
[FONT=Courier New]	[COLOR=#b1b100]for[/COLOR] [COLOR=#66cc66]([/COLOR]j = [COLOR=#cc66cc]0[/COLOR]; j < [COLOR=#cc66cc]1275[/COLOR]; j++[COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]
[/FONT]
[FONT=Courier New]    LCDPORT = [COLOR=#66cc66]([/COLOR]c << [COLOR=#cc66cc]4[/COLOR][COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]    delay[COLOR=#66cc66]([/COLOR][COLOR=#cc66cc]2[/COLOR][COLOR=#66cc66])[/COLOR];[/FONT]
[FONT=Courier New]    lcd_data[COLOR=#66cc66]([/COLOR][COLOR=#cc66cc]2[/COLOR][COLOR=#66cc66])[/COLOR];        [COLOR=#808080][I]// just send "1" to lcd to display ;[/I][/COLOR][/FONT]
[FONT=Courier New]    P3 = 0xf0;[/FONT]
[/FONT]
used diffrent delay whats the wrong with it ?
in your program where did u configure your port pins that you have connected to LCD ??
why did you write functions in header file ?
yes given P2 = 0x00;
but nothing happens .
i used header file firstly but in keil i cant debug correctly without header file can be check the register value ...
whats the wrong with me ?
#define LCDPORT P2
[COLOR="#008000"]sbit RW = P2^1;[/COLOR]
sbit RS = LCDPORT ^ 2;
sbit E = LCDPORT ^ 3;
void lcd_cmd(unsigned char c)
    LCDPORT = c & 0xf0;
    RS = 0;
    RW = 0;
    delay(10);
    latch();
    c = (c << 4);
    LCDPORT = c & 0xf0;
    RS = 0;
    RW = 0;
    delay(10);
    latch();
void lcd_data(unsigned char c)
    LCDPORT = c & 0xf0;
    RS = 1;
    RW = 0;
    delay(10);
    latch();
    c = (c << 4);
    LCDPORT = c & 0xf0;
    RS = 1;
    RW = 0;
    delay(10);
    latch();
But sir RW already have connected to ground , is that 0 ?
Writing to LCDPORT resets also the lower P2 bits to zero, in this case RS. Means you are always writing to command register, never to data.
LCDPORT = c & 0xf0;
thanks sir ., may i know how to send RS value along with data value . can I use an OR function ?
LCDPORT = c & 0xf4; ?
