[SOLVED] LCD 16x2 4 bit interfacing problem
Ranbeer Singh
Full Member level 5
Full Member level 5
Faridabad India
Hello All,
I am unable to send the 4 bit data to Pic18f2520 PORTC upper nibbles. Actually i do'not have any idea to send 4 bit data to 8 bit port. If i work with LCD library, It works fine...but i have manufactured my PCB's. So i am unable to change pins and gate it's benefit.
Pin description : -
EN = RC3
RS = RC2
R/W = GND
PORTC upper nibble = data out​
My code are here
#include <p18f2520.h>
#define RS_PIN   PORTCbits.RC2   /* PORT for RS */
#define E_PIN    PORTCbits.RC3   /* PORT for E  */
void LCD_Init(void);
void Str_LCD( const rom char *buffer);
void Chr_LCD(char data);
void Clear_LCD(void);
void Move_Corsor( char Line, char Pos);
void Start_Display(void);
void Time_10ms(void);
void main()
	TRISA=0xFF;
	TRISC=0x00;
	PORTC=0x00;
	TRISB=0x01;
	PORTB=0x00;
	T0CON=0x06;
	LCD_Init();
	while(1)
		Start_Display();
void Start_Display()
	Str_LCD("SPEED- ");
	Str_LCD("0000");
	Str_LCD(" RPM");
	Move_Corsor(2,0);
	Str_LCD("Current- ");
	Str_LCD("2.2");
	Str_LCD(" A");
void LCD_Init()
	RS_PIN=0;   		   //LCD instructions (RS) pin no. 4
	Chr_LCD(0x28);		   //LCD clear
	Chr_LCD(0x01);		   //LCD 4 bit, 2line, 5x7
	Chr_LCD(0x0C);		   //LCD diplay-on cursor not blinking
	Chr_LCD(0x80);		   //LCD cursor Pos. begain
	RS_PIN=1;  			   //LCD Data (RS)
     while(*buffer)                 // Write data to LCD up to null
             Chr_LCD(*buffer); 		// Write character to LCD
             buffer++;              // Increment buffer
        return;
	TRISC &= 0x0F;
	PORTC &= 0x0F;
	PORTC |= data&0xF0;
	Time_10ms();
	Time_10ms();
	Time_10ms();
	E_PIN=1;
	Time_10ms();
	Time_10ms();
	Time_10ms();
	E_PIN=0;
    PORTC &= 0x0F;
    PORTC |= ((data<<4)&0xF0);
	Time_10ms();
	Time_10ms();
	Time_10ms();
	E_PIN=1;
	Time_10ms();
	Time_10ms();
	Time_10ms();
	E_PIN=0;
	TRISC |= 0xF0;
	RS_PIN=0;
	Chr_LCD(0x01);
	Chr_LCD(0x80);
	RS_PIN=1;
	RS_PIN=0;
	if(Line==1)Chr_LCD(0x80);
	if(Line==2)Chr_LCD(0xC0);
	while(Pos!=0)
		Chr_LCD(0x14);
		Pos--;
	RS_PIN=1;
void Time_10ms()
	TMR0H=0xFE;
	TMR0L=0x7A;
 	T0CONbits.TMR0ON=1;
	while(INTCONbits.TMR0IF==0);
	T0CONbits.TMR0ON=0;
	INTCONbits.TMR0IF=0;
Please help
void Lcd_Write_Char(char a)
char temp,y;
temp = a&0x0F;
y = a&0xF0;
RS = 1; // => RS = 1
Lcd_Port(y>>4); //Data transfer
EN = 1;
__delay_us(40);
EN = 0;
Lcd_Port(temp);
EN = 1;
__delay_us(40);
EN = 0;
Thank you for your reply.
I want to know how is it working? I mean you are shifting data to upper nibble...but how did you?
Please..... Can you explain me?
hi, eventually
check datasheet of microcontroller for each pin you use with LCD. It happened to me that some pins did not have internal pull up rezistor so i had to add them on the back of pcb . Code was ok .
Just to be shore is not hardware problem
hi zsolt1
I have tested my code on Proteus simulator. When i make a 8 bit interface. It work fine. But when i want to interface with 4 bits... nothing works. I know that any problem with my void Chr_LCD(char data). Because when i send data to all port.. works fine.
What do you feel for void Chr_LCD(char data)
This is a shift right. So the upper nibble become the lower nibble.
I think this is wrong.
You should shift the lower nibble 4 bits left, so it becomes the upper nibble.
Klaus
Anybody can explain me how it's shifting.
For example: -
data = 'A'; // In ascii
data = 01000001 // in binary
Now then we send data in 2 parts. Upper nibble is 0100 and lower nibble is 0001.
What nibble should be send first?
I don't know, but it surely is in the display's datasheet.
">>" is the shift right operator
"<<" is the shift left operator.
The parameter (4) behind the operator says the count of bits it is shifted.
You should also find the information in your compiler's documentation. Look for "shift", or "shift operator".
Klaus
As per your guidance i am trying to understanding it's consent. i make 2 local variable for this function. I will store upper nibble in one and lower in second variable. Now it will lock like this.
char up, down;
up = data & 0xF0;
down = data & 0x0F;
Result will come : -
up = 0000 0100 // Distance sow only for understanding
down = 0000 0001
PORTC = up<<4;     // up lower nibble send to PORTC upper nibble
EN = 1;
Delay();
EN = 0;
PORTC = down<<4;    // Down lower nibble send to PORTC upper nibble
EN = 1;
Delay();
EN = 0;
It is write?
I have connected EN & RS pines to PORTC lower nibble. Will these pins not wrong functioning?
It is write?
Sorry...I was writing Is it right?
If you use 'up = data & 0xF0;' it makes the lower 4 bits all zero (read about the logical AND instructions). Therefore 'PORTC = up<<4;' will always output zero on it's upper bits. As explained, the << instruction moves all the bits in the variable to the left (towards the most significant bit) by the number of places following it. You have an 8-bit value to be split into top 4-bit and bottom 4-bit halves. The top already holds the bits you need so all you have to do is remove the bottom part before sending it to the port.
PORTC = up;     //  send to PORTC upper nibble
EN = 1;
Delay();
EN = 0;
the lower 4 bits have to be moved up to the positions of the high bits by shifting to the left 4 times:
PORTC = (down << 4) & 0XF0;    // Down lower nibble send to PORTC upper nibble
EN = 1;
Delay();
EN = 0;
Beware of the potential trap here, by writing to PORTC you change ALL the bits in the port so bits 3:0 are also changed (set to zero in this case). If that will cause problems in your hardware, the trick is to read PORTC to a variable, AND it's value with 0X0F so the top bits are all zero, then OR it with the LCD bits you just generated. The variable will then contain the original lower bits and the new upper bits, you then write it back to PORTC.
Brian.
    V
up = data & 0xF0;
down = data & 0x0F;
Imagine the data byte is 0x69.
then after your "masking":
up = 0x60
down = 0x09
for a clean implementation i recommend a read-modify-write technique.
(I´m not familiar with C, so pleas see it as a guidance, not as C code)
x = portc (read in previous state of portC)
x = x AND 0x0F (clear upper = data bits) (!!! corrected: here was an OR instead an AND)
portC = x OR up (set NEW upper = data bits)
Klaus
hi
i'll write from memory ...
I remember that i used PORTB high nibble B7...B4 connected to lcd 13,12,11,10 . So my function was like
Code C - [expand]
8
9
10
11
12
void TxChLCD(char word, char i)
//and looked like this
 RS=i ; // i=1 wrt data word  , i=0 wrt instruction word
PORTB=PORTB & 0b00001111; // clear data bus to lcd
PORTB=PORTB  | (word & 0b11110000); // put high nibble first on the data bus
EN=1; _delay(2);EN=0; // tell the lcd to take in the data present on the bus
PORTB=PORTB | (word<<4);  // put the lower nibble on the  bus
 EN=1; _delay(2);EN=0;// tell the lcd to take in the data present on the bus
_delay(140);
I don't know for shore what pins i used ... maybe lower bits of PORTB , B3,B2,B1,B0 connected to 13 ,12,11,10 of lcd
Than code would be like so:
Code C - [expand]
8
9
10
11
12
PORTB=PORTB & 0b11110000; // clear data bus to lcd
PORTB=PORTB  | (word >>4); // put high nibble first on the data bus
PORTB=PORTB | (word & 0b1111000);  // put the lower nibble on the  bus
_delay(140);
It was a stroboscopic rpm meter , if i'll found it i'll post it (i think i did somewhere here :thinker: )
This is your function:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
    TRISC &= 0x0F;
    PORTC &= 0x0F;
    PORTC |= data&0xF0;
    Time_10ms();
    Time_10ms();
    Time_10ms();
    E_PIN=1;
    Time_10ms();
    Time_10ms();
    Time_10ms();
    E_PIN=0;
    PORTC &= 0x0F;
    Time_10ms();
    Time_10ms();
    Time_10ms();
    E_PIN=1;
    Time_10ms();
    Time_10ms();
    Time_10ms();
    E_PIN=0;
    TRISC |= 0xF0;
I would try it like this :
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
    TRISC &= 0x0F; //  this is what you do first after cpu setup so would not use it here
    PORTC &= 0x0F;
    PORTC |= (data&0xF0);
        _delay (1);                  // ok let's say  i'd put here 1 us delay , thus not needed at all
    E_PIN=1;
        _delay(3);                 // 3 us is more then enough for the lcd to reed the bus
    E_PIN=0;
    PORTC &= 0x0F;
    PORTC |= (data<<4);  // when you shift 4 positions to the left the lower part fills with 0 by default
                                      //  x x x x 0 0 0 0
    E_PIN=1;
    _delay(3);
    E_PIN=0;
     // why to make the pins input by  TRISC |= 0xF0; are you going to disconnect the lcd or what ?
PS: i was using Hi tec c compiller of Microchip. It had _delay (x); function to call to do microsecond delay
Actually i am using PORTC for LCD and PWM is also there. Please see circuit given below and remark PWM also.
Dear
When i send data to port C. It will make PORTC lower nibble 0000. But i don't want to make these pins 0. i want to leave these pins in previous status. Because if PORTC = xxxx0000 ... It will make EN = 0 & RS = 0 also. It mean LCD data receiving = No & Data instruction = Yes. So how it will work.
Actually i don't want to disturb lower nibble.
There are several code examples in this thread that solve this problem, e.g. the OR operation in post #1 and post #13. Using this method you shouldn't have a problem of overwriting port bits inadvertantly.
One issue is "input/output" (direction)
The other is "data".
They are different.
Direction: as far as I can see the whole port may be configured as output. Continously.
Data: See solutions above.
Klaus
Ok
I will try to these replies (#1 & #13) codes.
I was referring to the way the port nibbles are controlled, I don't think that the codes should be used as is in all details. There are many unreasonable points, e.g. huge delays. It's required that you study the LCD interface requirements and correct the codes respectively.
There are tons of similar codes on the internet and code examples shipped with LCD displays or compilers. Many of them are probably better considered than the code examples posted in this thread,
You have to send only 4 bits to the port
Most probably this is an 8 bit access, so you can´t send only 4 bits.
Klaus
