OpAmp said:Of course, it does matter. Because the above rule is one of many rules that you should satisfy to have a good matching. Common centroid is in addition to the above rule and it is for eliminating first-order temprature and process variation across the wafer.
OpAmp
hung_wai_ming(at)hotmail.com said:Can u post the whole lecture here?
wonbef said:another layout matching technique is network layout matching. but it is more complicated.
hung_wai_ming(at)hotmail.com said:I would also add dummy magnet-like POLY to improve POLY end mis-matches.
