dac5bits
Banned
Background:
in layouts I have seen, usually dummy transistors are used when the source is connected to vdd or vss (PMOS or NMOS respectively). no body effect to worry about.
Question:
can you use dummy transistors when the PMOS source is connected to the well to remove the body effect (standard CMOS n-well process)?
if so are there any issues here?
Question:
