A resistor is required by some crystal oscillators. If so it's specified in the IC data sheet. If not, it's useless, I think. I presume it's not required here.But usually I add a resistor in parallel to the XTAL. Leave it nc when not used. But it can help to ensure start up and improve start up time.
The pins are specified as ground pins for most 4-pin SMD packages and connected to metal cover. They should be connected to ground, but there's no particular need for more than one ground via.For usual Xtals I don't connect the unused pins to GND nor do I place a GND ring around the XTAL.
Mind: your layout increases stray capacitance, maybe you need to adjust the values of the capacitors.
Interesting. After reading this I did check all of the datasheets of my XTALs in stock.The pins are specified as ground pins for most 4-pin SMD packages and connected to metal cover.
do i need to add more GND vias on the yellow round mark to GND layer?
I'm using NDK crystal, in the datasheet, it specified other 2 pins are GND (connection cover).A resistor is required by some crystal oscillators. If so it's specified in the IC data sheet. If not, it's useless, I think. I presume it's not required here.
yes, from the datasheet and AN of the IC, the resistor is not needed.
