Saltwater
Member level 4
I have two ECW20N20 Lateral mosfets. https://www.exicon.info/PDFs/ecw20n20.pdf
And I have set them up as a common emitter amplifier. With a resistor before the load and the transistor acting as a varistor to ground.
But I don't get these parts very well, or I am doing something wrong. Or is there something wrong?
I have them set up at 20V and the current they draw through the resistor is about 1.33A.
Looking for the bias point, the bias point is below two volts. And the voltage swing is about a volt.
Where the transistor is only operating at a few milivolts. Which is hardly an amplifier.
The data sheet seems a bit out on this as well, in being brief.
Is this OK? does this mean I have to supply loads of current to one of these to get a decent amplification going?
