quack1
Newbie level 1
I'm new to electronics. I'm designing a product using a retroreflective laser emitter/sensor. The laser emits light that is reflected off a target back at the sensor. The laser is powered off of two 9V batteries in series (18V). It's rated consumption is 35mA and output is 100mA. In addition to its positive/negative leads, it has two negative outputs for control of alarm or other load.
I want the laser to send a signal to a piezo buzzer when light is reflected back at emitter/sensor from the target. The piezo buzzer is 3-16V DC 7mA. What would I need to put in the circuit to make this work...if it's even possible?
Thanks!
Thanks!
