nips
Newbie level 6
laser detection circuit
I want to build a laser transmitter and receiver for use in my robot's positional system.
Anyone with info, links,circuit ideas ?
Do i need to use modulated laser to avoid interference from ambient light.
I intend to use the laser in laser-pointers as they are cheap.
Will normal photodiodes work ? How do i build them so that they receive only the modulated beam rejecting other frequencies.
Here's how the positional system would work:
The laser is mounted on a rotating motor.The co-ordinates of 3 detectors are known and the angle subtended by the detectors can be found when the laser hits the targets(detectors).Using triangulation, the position can be calculated.
