datsystem
Newbie level 6
hi everyone.
i hv some questions about the large dot matrix led display...
if i want to use the larger size dot matrix led,can i use the same program to control it?
which of the transistor i should use to amplify? when i need to control 6 of them
i also need to know which type of shift register is suitable for them....i afraid that there is not enough port for me to connect it...
if i use the RGB dot matrix led display, what is the different between RGB and only have one color led??
for the control operation, i would like to use the RF to control it, if i need to connect it, should i need to use the IC to connect it and use it to connect to the microcontroller? the RF i may make about 4 buttons on it,..
i also want to control the brightness for it, if i use the c language to write the PWM, how can i write it?
because i need to connect it to computer with usb, for the hardware, what should i need to focus more? because i have not done it before, should i need to use the IC to connect the USB and the microcontroller?
can someone help me??
i also wanna know is the anode dot matrix led display is better?
