Large difference between the 1dB compression point and the IP3
elbadry
Full Member level 6
Full Member level 6
Egypt
I am using Spectre RF for a mixer design. When I use a two tone test to get the IP2 (using swept qpss) I usually get a very large difference between the 1dB compression point and the IP3.
According to theory, IP3=P1dB+9.6 dB
However I get difference as large as 16 or 18 dB, what can be the problem?
Thanks in advance
