eriksen
Junior Member level 1
As you can see in the picture attached I have coin cell application. The positive terminal of the battery is connected directly to the VDD plane and then there is a large cap(100u_1210) connected to the plane aswell further away.
My question/concern is if the circuit might draw high currents from the battery instead of getting the current from the cap. Should the positive terminal be connected to the cap, and then the cap should be the only source of VDD to the VDD plane or isn't this necessary?
My thoughts when designing was that: When the radio goes into TX and draws approx. 20-30mA, then the battery voltage would drop and the cap would start to discharge to compensate for the drop regardless if the VDD was forced "through" the cap.
Any thoughts would be greatly appreciated.
Thanks.
-Fredrik
Thanks.
-Fredrik
