This project is a result of experiments and processing of several versions of preamplifier, inverter etc. Point-to-point method was used to facilitate the possibility of modifying.
Chassis was designed in AutoCad and cut using laser in inox steel. Housing is osb3 board covered with tolex. Front was made of plexiglass plate that was laser engraved.
Front panel was finished with foil, such as it is used for wrapping cars, resistant to abrasion, moisture, cold and heat.
Technical data:
- output power 100W lamps 4x 6n2p + 4x 6p3s-e, output 4, 8, 16ohm
- 2 channels with separate correction
- 3 effects loops (one per channel plus one common)
- common presence
Pictures:
Link to original thread (useful attachment) – Lampowy wzmacniacz gitarowy
