[SOLVED] label location in layout
M
MohEllayali
Newbie level 1
helleo everybody
the way i define my ports is by using a lable in a special layer (whith pin purpose)
it turns out that the extracted netlist will depend on the location i will put my label in
is there any good recomandation where to put my label in ?
many thanks
I would suggest that you attach the label on the pin (this capability is being given by LAYOUT XL of cadence virtuoso,you will find it from the top menu bar).Be careful to use the same layer (the special one you mention ) and the same name with the pin.I thinks this is what you are looking for,right?If not do not hesitate to ask for more assistance.
Regards,
Jimito13
In LAYOUT XL of cadence virtuoso, u can lable by pressing L , and if your lable is not viewd on next time when u open your layout, just press E u can see the option pin name, click it and press ok, than the lable can be viewed
the label origin marked by a + symbol has to be on top of the layer you want to stamp as a port; play with the justification setting if you want to have your labels visible e.g. hanging outside the bBox of your design
The presence of an actual pin is completely irrelevant for some tools (e.g. Calibre)
the attach option is available in basic Virtuoso w/o the XL option but it will be irrelevant if your extraction is label based (e.g. Calibre)
