L\eonard0 Spec\trum For ASIC Synthesis
eda_wiz
Advanced Member level 2
Hi all,
how good is leonardo Spectrum for ASIC Synthesis. I am getting Huge gatecount for a small Logic in spectrum :(
helppp
tnx
I haven't experience with LS but every time that I have used it I had problems.
The solution can be to use a serious synthesis tool :)
2003a_RC_9 seems to be (pre-)released.
but can't use lic for 2002e.
is it powerful than DC when synthesis?
maybe it it quick then DC,but how is it effect?
A link please?
This gate count are always confusing.
Different tool has different criteria.
I have used Leonardo Spectrum now for a year and half for developing for Altera ACEX1K50. I would say, the tool is useful; some features are god others so-and-so. In my particular configuration I used MAX II Plus for the physical layout, while the source code was VHDL. The combination Leonardo and MAX made me to loose track of the physical elements<->VHDL source code completely, so floor planning was a nightmare. I had no problem with space, but speed was a issue, so manual optimization was needed.
In the end I converted to use Quartus II 2.2, and its native VHDL compiler. Now I can see the connection between VHDL and the floor plan much better. Of course, Quartus has a much better "timing closure" floorplanning functionality than MAX II Plus anyway.
What I miss from Leonardo is the "generated schematics" stuff, which I used for block-schematics level documentation. Generated logic however was not that good and the grazy node and net names generated by Leonardo->edif file->MAX was the biggest curse. Somewhat inefficient code generation was not fun either. There the difference was not that big, however.
I would not compare Leonardo against any other system, because the only VHDL -> FPGA compilers I have used are the above mentioned ones. And I decided to get rid of Leonardo Spectrum in favor of Quartus II 2.2
And I had FPGA, not an ASIC as my target. But, I guess, some of the wonderful synthesizing grazyness is valid for Leonardo in all instances. In several cases the logic wasn't pretty ! But my technology dependent libraries were not equal to yours, so the wild gate count might have some connection to the library implementations, too.
Ted
