Sara88
Junior Member level 1
Hi everybody,
I'm trying to simulate 850-900MHz Koch curve dipole antenna by using AWR microwave but i'm quite new with this and not familiar with its settings.
I tried to follow some of the examples and tutorials in the internet and "getting started" from the Help option but i have a lot of questions.
1) How do i know what is the suitable simulator for my design, for example there's AWR AXIEM & AWR EMSight Simulator.
2) Which kind of ports should i use "Edge port" or "internal port"? and i connect one port or two. and where should i place them?
- I simulated with two internal ports attached to the two shapes at the gape- But i can't get the expected results within the range freq -
3) if i'm using EMSigt simulator it shows me a dimension of the enclosure "X=70 mm, Y=20mm" and asking for sidewalls ports to complete the simulation which i don't understand why? while in AXIEM simulator, it sets the suitable dimensions for my antenna. ( 62mm length and 10mm height and with 4.2 Er.) By these dimensions, how can i tune my shape to to match my requirements of 850-900MHz freq and -6 dB of return loss.??? What is the main element that should I focus to help me to get the expected results?
4) I already draw the shape of the koch curve of the third iteration by using path line, how ever i have reviewed some articals that can use circuit schematics to draw the curve by using MLIN & MBEND elements but i'm not familiar with that two, but i tried to build the circuit but the output layout does not match and its quiet messy, but i tried to use "snap together" option but still didn't work or i didn't know how??
5) Should i use Agilent ADS software to simulate or AWR is enough?
6) at first i tried using CST studio simulation for a long a time and wasted my time with it and end up giving up, because drawing fractals specially koch curve is not easy comparing to AWR which is much simpler. My question is, after i draw my third iteration of koch curve dipole antenna, i tried to import my design from the AWR to CST, but is says i can't edit or change and when i tried to simulate its stuck"
7) IS THERE ANYWAY THAT COULD MAKE MY LIFE EASIER????
Thanx.. I NEED YOUR HELP RESPECTED PEOPLE.. My deadline is in 29th of July" so i have should fabricated my design already, but its my first time to do antenna and using these software"
:grin:
:grin:
