Knowledge about Fixed Value variable attenuators
retpada
Banned
Newbie level 1
Fixed value variable attenuators currently have fixed values that happen to be described around decibels. Its uses involve telecommunication networks, optical fiber test facility, Local Area Network(LAN) and CATV systems.
Such as, your -3dB variable attenuator will need to cut down intensity of your expenditure by 3 dB(50%).
Fixed value variable attenuator's attenuation value are not to be mixed. The fiber optic attenuation is definitely mentioned around dB. A performing wavelength for variable attenuators really should be described for any rated fiber optic attenuation, for the reason that optical attenuation on the material deviates by using wavelength.
Fixed value variable attenuators consist with not one but two significant categories: In-line type and connector type. In-line type appears a plain fiber patch cable; there are your fiber cable terminated by using two connectors which you can lay down styles.
Connector type attenuator appears a bulk head fiber connector, there are a male end and a female end. Them buddies so that you can regular connectors of your exact style these as FC, ST, SC and LC.
Sopto presents full collection of variable attenuators including Fixed value variable attenuators. Besides, related products including fiber media converters ,**broken link removed**,E1 converter, PCIe network cards are available as well.
